RV.Net Open Roads Forum: Adding electric heat element to gas water heater
 > Adding electric heat element to gas water heater
TurnThePage
North ID
Posted: 09/29/22 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Because my old travel trailer may need to be permanently occupied for the next 6 months or so, I'm considering adding an electric heating element to the gas only water heater. The tank is aluminum, and it looks like the available kits use brass fittings. I'm concerned about galvanic corrosion. Anybody have experience with these things?
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
agesilaus
North Florida
Posted: 09/29/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Not with the kits, but yes Aluminum and Brass will set up a galvanic cell. Putting a insulating gasket in between the brass fitting and the tank may prevent the corrosion. A piece of teflon or rubber would work.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
Bumpyroad
Virginia
Posted: 09/29/22 10:05am Link  |  Quote  |  Print  |  Notify Moderator
On one of my gas only water heaters I added a hot ROD I think it was called.
worked but a bit slow.
bumpy
opnspaces
San Diego Ca
Posted: 09/29/22 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I may be wrong but I don't think galvanic corrosion happens very fast.
I would probably buy a electric element and screw it into the tank. Then after 3 months turn off the water heater and let the tank cool. Then pull the element and see if you notice any corrosion on the threads. It none then screw the element back in and check again in another 3 months.
After your 6 months remove the element and put the plastic drain plug back in.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
TurnThePage
North ID
Posted: 09/29/22 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I've already ordered a kit and will likely take that approach.
Thanks All!
agesilaus
North Florida
Posted: 09/29/22 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately the corrosion will occur on the aluminum side not the brass side. Aluminum will form the anode. I'd expect corrosion to occur at the contact zone between the brass and aluminum.
If the tank has a sacrificial anode, which it probably does not in a propane only heater, that may corrode instead of the aluminum.
pianotuna
Regina, SK, Canada
Posted: 09/29/22 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
There is one kit that includes a magnesium rod to protect the aluminium.
Regards, Don
midnightsadie
ohio
Posted: 09/29/22 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
wrap the threads with teflon tape good. slow things down
Posted: 09/29/22 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
$20 says you won't use anywhere near $120 (cost of a hot rod kit) in propane heating your water for 6 months.
Something to consider.
agesilaus
North Florida
Posted: 09/29/22 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
That will work
