RV.Net Open Roads Forum: Why not jack trailer under the spring plates?
 > Why not jack trailer under the spring plates?
Page of 5
phillyg
SWFL
Posted: 10/02/22 08:14am Link  |  Quote  |  Print  |  Notify Moderator
When it's said not to jack under an axle, it really means directly on the tube. How else would one place a jack if not under the spring pack?
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
time2roll
Posted: 10/02/22 08:17am Link  |  Quote  |  Print  |  Notify Moderator
ONE wheel? I jack under the u-bolt or spring plate. Wheel service only, do not get under the trailer.
ALL wheels? Lift by the frame.
675w Solar pictures back up
BB_TX
McKinney, Texas
Posted: 10/02/22 09:21am Link  |  Quote  |  Print  |  Notify Moderator
!4 years on our 5th and I always jacked under the springs and never a problem.
MFL
Midwest
Posted: 10/02/22 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I have seen a few cases, of people actually putting their floor jack in an obvious wrong part of the axle tube. One case, two floor jacks, one under each axle of a fifth wheel, landing legs down, and the jacks placed between wheels and axle centers. He was packing bearings, too late anyway, so I didn't comment on his placement of jacks, lifting the whole side, with landing legs down.
There is quite a number of adapters for bottle jacks, that will cradle the axle tube, in the U-bolt area. I just made a wooden block, pictured in the recent travel trailer section, asking similar question. Works good for me!
Jerry
Cummins12V98
on the road
Posted: 10/02/22 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Who the HE!! said NOT to jack under the spring pack???
This tho is by far a better option especially alongside the road.
Oh yea the RV weighs 19k. I have also used on my 24k DRV.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Platte City, MO
Posted: 10/02/22 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I believe if you do some checking, it's the manufacturers that say not to jack up the trailer by the axles and use the frame instead. But, IMO, that is a simple CYA. If they said it was okay to use the axle, then some nimrod would end up jacking in the middle of the axle so they could lift both sides, or some other moronic reason, and then complain when the axle bends: "But it said I could use the axle to jack up the trailer. It's not my fault".
Howard and Peggy
"Don't Panic"
red31
Dallas
Posted: 10/02/22 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I find the frame easier to access than what is behind a wheel.
Alan_Hepburn
San Jose, Ca, USA
Posted: 10/02/22 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I've never heard anyone say not to use the spring perch; on the contrary I've always heard to use the spring perch as opposed to using the axle tube itself.
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
MitchF150
Puyallup, WA
Posted: 10/02/22 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I know this is all about jacking rigs with leaf springs... That's why I like my torsion suspension setups I've had on the only 2 rigs I've owned for the last 20 years..
This is my old 2003 Prowler Lynx TT. What you don't see in the pic is the jack stands on either side on the frame as well. The bottle jack is just there to get the tires off the ground initially and then I put the stands under and release the jack so it's just there to jack up again to remove the stands..
Anyway, I've done the same on the Rockwood, I've just gotten a larger bottle jack cause I needed more extension on the pistons..
And NO, the frame is NOT bending... It's just the way the picture came out.. [emoticon]
Mitch
Southern California :(
Posted: 10/02/22 11:59am Link  |  Quote  |  Print  |  Notify Moderator
If under warranty and you Jack from springs when manufacturer says no and something goes wrong…no coverage.
Page of 5
