RV.Net Open Roads Forum: Class A Motorhomes: 1995 CHEVROLET P30 CHASS STEERING ISSUE
 > 1995 CHEVROLET P30 CHASS STEERING ISSUE
YumaBill20222
yuma arizona
Posted: 10/04/22 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Working on my 1995 Chevy P30 Chassis and have developed an unusual steering vibration after replacing my bell cranks. Had found out after install the original bolt where bell crank attaches to forward moving steering stabilizer was too short and worked itself loose and blew out the cylinder. installed new cylinder with correct length bolt but side to side wobble in steering still present. Replaced 2 front tires installed upgraded h/d steering stabilizer replaced front shocks and replaced bearings in super steer bell crank mounts and still have the side to side movement only occurs when hitting any type of bump or dip in road...looking for any help i am sure its something we are overlooking PLEASE HELP
opnspaces
San Diego Ca
Posted: 10/04/22 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if your chassis has a trac bar but if it does I would replace those bushings.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
MountainAir05
New Mexico
Posted: 10/04/22 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
This is a list of things that can cause what you have. I am sure there are others to be add to it. Something has a loose joint, you just have to find it. Good luck or go find a good front end shop that knows the P30.
Front Track Bar
Ball Joints
Drag Link/Tie Rod Ends
Upper Control Arms
Lower Control Arms
Suspension Bushings
Steering Stabilizer
Steering Knuckles
enblethen
Moses Lake, WA
Posted: 10/04/22 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Is your rig equipped with air bags?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ROBERTSUNRUS
Salem, Oregon
Posted: 10/04/22 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, anything that is loose or worn and zero toe-in.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
1995brave
San Antonio, TX
Posted: 10/05/22 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Check the chassis metal around the bell crank and steering box for cracks.
YumaBill20222
yuma arizona
Posted: 10/05/22 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the responses everyone.. it does not have air bags and everything bushing and control arm wise have no play or movement.. the weird thing is its not a turning vibration it only move the steering wheel side to sidelike your panning for gold if that makes sense
enblethen
Moses Lake, WA
Posted: 10/05/22 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Did vibration start before or after new tires?
Possible rim is not tight against hub.
YumaBill20222
yuma arizona
Posted: 10/05/22 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
It started after replacing bell cranks
wolfe10
Posted: 10/06/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
If no air bags, sure hope you have Henderson's stronger springs.
The air bags were an integral part of the front suspension, and are critical for proper alignment.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
