RAS43
Littleton,CO
Grit dog wrote: phillyg wrote: I've been disappointed the few times I strayed from Michelin.
I've been disappointed the couple times I've had Michelins.
Same with me.
valhalla360
No paticular place.
joelyn wrote: fj12ryder wrote: Just curious why you want an all terrain tire if you don't intend to go in the dirt? A straight hiway tire will be quieter and give you a smoother ride. And do better on ice.
I generally buy the cheapest. Works for me for over 50 years. But I do things differently with the bike. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
I live in the rural section of Az all dirt roads like washboards. so thats why i think i would like a stronger tire for to and from the main roads and house...... i had the Passenger tires on the truck when i bought the truck in 2012 and they only lasted 20 ,000 miles before all tires got flats within 2 weeks of each other and all split right in the threads from the rocks...... at that time the tire guy advised me to get the LT tires and go from the P275/60R20 to the LT265/20R20 size and made a huge difference and never a problem again with flats or anything. have 40,000 miles on them now and thread is hardly worn, sidewalls still look good but the heat is a killer out here and so far 6 years might be getting to the worn point from the heat... truck rides really smooth and quiet and to me even better that the OEM P275/60 R20 tires and never have ice out here so i figured i would stick with them. just some sticker shock compared to when I bought these, LOL................... thanks for your post
Get an LT matching the size and load index (weight rating) you need. After that, I go with the cheapest and have always done well.
Not off roading but a highway tread will do just fine on dirt roads.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Contrary to my previous post there are a couple tires I DONT like.
1. Is anything that starts with Michelin….but whatever.
2. GY Duratracs. First the good. They wear as well as any quality AT/MT tire. They actually out kick their coverage in the treadwear department considering how aggressive they are and how good of traction they get in inclement conditions. But something about that particular tread design pattern (a pretty exclusive pattern. Don’t see others that look similar) makes them far and away the loudest tire that is not a dedicated mud tire (Talking tires like Swampers, not your run of the mill MTs) that I have ever used.
On my second set. First ones I bought voluntarily. Held up well considering 95% of the miles were basically I-70 and SH82 in Colorado. High speed mountain curves. A year of commuting through Glenwood Canyon at far greater than posted speed limits… They were howlin mofos!
Current set, OEM on my Trailboss. 45k miles and I’d still run them this winter no problem tread wise. And I drive over Snoq Pass couple times a week year round. Wonderful tread life.
But they are literally louder than ANY other MT tire I’ve ever had. Hands down, no contest. So loud that at certain speeds they actually resonate in the cabin. And I’ve rotated them no less than a half dozen times since new. Back tires to front, they quiet down a little because the minor tread feathering that happens on steer tires has been flattened out by running on the drive axle. And within a few tanks of gas they’re back to sounding like 44” Interco TSLs!!
I’d use them in a heartbeat in only snow conditions or jeepin. They are horrible for a daily driver.
mkirsch
Rochester, NY
administrator/moderator wrote: * This post was edited 10/05/22 11:16pm by an administrator/moderator *
Huh? It was censored.
mkirsch wrote: administrator/moderator wrote: * This post was edited 10/05/22 11:16pm by an administrator/moderator *
Lol, you're gettin' doxxed by rvnet, Matt!
Pbutler97
Midwest
All Terrain
Highway
Badass
You can not go wrong with this brand, performance division of Sumitomo.
shelbyfv
TN
I've always been happy with Michelin Defender LTX M/S. Michelin at Discount Tire I've had several sets and they do well on dirt roads. Here's some discussion about them, off pavement. Expedition Portal
blt2ski
Kirkland, Wa
Grit dog wrote: mkirsch wrote: administrator/moderator wrote: * This post was edited 10/05/22 11:16pm by an administrator/moderator *
Not me, but do agree with what was first paragraph
"Opinions...... stink ??!
I also agree with grits long winded GY Duratracs comments. I'm about 20k miles. The front edges do wear quick! I'll swag my city driving at 80%,is causing this issue vs grit having 80% highway driving speeds, does not cause issues like mine.
I can't hear tone on a piano above an octave above middle C between Eand F kekeys. I hear E tone, F I hear hammer hitting the wire tapping. I hear these tires! Yes great in snow, not so great on sheet ice/snow, not enough micro sipping. After market sipping voids warranty! Boo hiss!!!
Should've stuck with Cooper AT3 like I had on 2500, both sons have on their trucks.
Marty
2014 Chevy 1500 Dual cab 4x4
FishOnOne
The Great State of Texas
I like tread on those AT's. I wonder where these tires are made?
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Pbutler97
Midwest
Japan
![[image]](https://i.imgur.com/P9LxeBxl.jpg)
![[image]](https://i.imgur.com/zScegaQl.jpg)
SUMITOMO RUBBER INDUSTRIES, LTD.
MIYAKONOJO CITY, MIYAZAKI PREFECTURE
JAPAN
