RV.Net Open Roads Forum: Class A Motorhomes: 2009 Damon Avanti No power ?
 > 2009 Damon Avanti No power ?
tourusa
Ft Lauderdale
Posted: 10/05/22 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all fellow rvers
The quest continues with a 2009 Damon Avanti, low low miles with new batteries but no power in coach or engine, any ideas of the issue on this rig,
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
Southern California :(
Posted: 10/05/22 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Test the batteries? Clean and tighten connections?
tourusa
Ft Lauderdale
Posted: 10/05/22 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
it’s both house and engine separate battery banks
MountainAir05
New Mexico
Check your cable for reverse, or a small one left off. It can happen. Battery has already been stated. Does the gen work. Master power switch if you have one.
With meter check from pos post on battery to a chassis ground any place you have metal.
tourusa
Ft Lauderdale
Posted: 10/05/22 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yes this one is sat in a dealers who im negotiating the price as is and they haven’t figured it out, like you say check the generator if it gets power from the batteries then shore power
Could it be the ECM or haven’t we got there yet if it’s dead
ArchHoagland
Clovis, CA, USA
Posted: 10/05/22 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Have you yourself actually measured the voltage at the battery terminals?
Sitting on a dealers lot they may have run down.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
tourusa
Ft Lauderdale
Posted: 10/05/22 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Hi they pulled it in today and charged all swapped out the batteries so they say
Posted: 10/05/22 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
If it's sat long enough on a dealer's lot the batteries can go FLAT (no charge won't take one either) But I'd be a bit... Watchful of the batteries till you are sure they are charging.. Also might want to look up the converter or other charger device (inverter/charger) and let us know the make and model. Some are good.. Some fantastic. Some.. Well Some I'd recommend an upgrade now.
tourusa
Ft Lauderdale
Posted: 10/05/22 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hi so bad invertor could stop the engine from starting ?
midnightsadie
ohio
Posted: 10/05/22 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
mice ate the wires.
