RV.Net Open Roads Forum: Honda 2000 won’t run my late model home furnace
 > Honda 2000 won’t run my late model home furnace
C Schomer
Pueblo West, Co.
Posted: 10/05/22 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I never use it for camping anymore and I only keep it cuz of my crappy power company. It will run the frig but the furnace is too fussy. Is there a device that will make it pure sine wave and will it then run the furnace?
Next ?… are all pure sine wave gens created equal so they will run this furnace or does it take a special model. Thanks, Craig
* This post was edited 10/05/22 04:29pm by C Schomer *
Fisherman
Angus, Ontario, Canada
Posted: 10/05/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
You may have to take an extra male plug and put a piece of 14 ga wire across the green (ground) and neutral (white), that's what I've been told. Then plug that into the generator while it's running.
2oldman
NM
Posted: 10/05/22 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
It already is pure sine wave. What is the fuel source for this furnace? What happens when it fails to run it?
Fisherman
Posted: 10/05/22 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Has nothing to do with the fuel source, there's a brazillion posts if you google it, modern furnaces need a neutral/ground bond, if they don't have it, they won't work. A lot of the inverter genny's are not bonded, therefore you can use a "cheater" male plug with the neutral/ground wires bonded. They even sell them.
bob213
Fresno, CA
Posted: 10/05/22 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Make a plug like this: and plug it into one of the 120v receptacles on the generator..It will think it's grounded.
time2roll
Posted: 10/05/22 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
How long is the extension cord? Is the cord #12 or #10 wire?
I assume this is a furnace with a burner so mostly just running maybe a half HP fan motor.
675w Solar pictures back up
ROBERTSUNRUS
Salem, Oregon
Posted: 10/05/22 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] My furnace, HVAC system, runs on 240 volts. So my generator won't run it either.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
2oldman
NM
Posted: 10/05/22 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Fisherman wrote:
Has nothing to do with the fuel source, .
Has everything to do with the fuel if it's electric.
Posted: 10/06/22 04:23am Link  |  Quote  |  Print  |  Notify Moderator
I though the Honda EU-2000i Was PSW. if it's an older non inverter generator than the device to make it pure sine wave is ... Kind of expensive (Very expensive) a EU-3000i would be cheaper.
How big is the furnace's blower.. Good chance the starting current exceeds the generator's ability.
valhalla360
No paticular place.
Posted: 10/06/22 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Furnace implies it burns fuel. Otherwise it would be an electric heater and 2000w is no where close to enough for a whole house electric heating system.
As others have mentioned, it's nothing to do with the sine wave but with the grounding.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
