RV.Net Open Roads Forum: Honda 2000 won’t run my late model home furnace
 > Honda 2000 won’t run my late model home furnace
C Schomer
Pueblo West, Co.
Posted: 11/23/22 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Bonding worked! My 5er required bonding and so does my home Armstrong furnace so I opened up the Honda panel and bonded neutral/grd. permanently.
I always run my gen on eco throttle so it only runs at the rpm necessary. I ran my furnace on hi blower and the Honda stayed at minimum rpm... it hardly noticed the small load. My UEI amp-clamp bit it, so I couldn't get the amp reading.
BTW, UEI is throwaway junk. I'm going back to Fluke. Craig
C Schomer
Pueblo West, Co.
Posted: 11/23/22 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer, that transfer sw. set-up in the 4 sq. cover is nice but I made my own with a $6 DPDT, on-off-on, 20A/125V toggle.
While I was adding the sw. to the furnace, I decided to run a romex to the garage because that's where the gen. will be. No more 100' ext. cord needed. Craig
C Schomer
Pueblo West, Co.
Posted: 11/23/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Ooopps, double!
3 tons
NV.
Posted: 11/23/22 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
ROBERTSUNRUS wrote:
[emoticon] My furnace, HVAC system, runs on 240 volts. So my generator won't run it either.
My furnace is a woodstove. My Honda doesn't do much for it either....
Relevance?
OMG, just think of all the plant fertilizer (CO2) you’re pumping into the atmosphere!!
3 tons
Bobbo
Wherever I park
Posted: 11/23/22 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the feedback.
3 tons wrote:
Relevance?
3 tons
As if the Honda doesn't generate any?
Bobbo and Lin
MrWizard
Traveling
Posted: 11/26/22 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Some years back when my brother bought his New Home, it was an electric furnace installed in the basement just as fi it was gas or oil, 230b wall thermostat, expensive yo yse when electricity prices started rising, a few years later a natural gas line was run through area and he switched , the mfg snd sellers dont call those heaters
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
C Schomer
Pueblo West, Co.
Posted: 11/27/22 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Electric furnace, air handler w/heat strips, most people know what they are, without getting any more technical. The worst set-up I had was heat pumps w/o heat strips, in the Phx area. It actually gets cold there... I've seen 13* and I think the record was 12. The HPs constantly cycled between heat and defrost (cooling) all night. I would have added heat strips if I would have stayed there.
BTW, My NG furnace draws 2.2A on hi-fire and hi-blower.. the generator hardly notices! Craig
