RV.Net Open Roads Forum: The Television won't pick up the cable channels
 > The Television won't pick up the cable channels
ken56
Tennessee
Posted: 10/05/22 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
For some reason my TV refuses to pick up the cable at the park I'm in. It's good signal at the post because it was checked. Not sure if it's my cable I use to hook up to it yet. Yes, the antenna booster is off. Just frustrating minor glitches that have to be too easy to fix but.....Oh well, off to the store tomorrow.
bgum
South Louisiana
Posted: 10/05/22 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ken if it is good at the post I would try a different cable to your rig. If that doesn't work try bypassing your rigs wires by going directly to the tv.
HappyKayakers
Somewhere in the USA
Posted: 10/05/22 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Changed channel source and rescanned?
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
mockturtle
AZ
Posted: 10/05/22 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure your TV input is set to 'cable' rather than 'air'.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
BB_TX
McKinney, Texas
Posted: 10/05/22 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
X2. Source set to cable and rescan.
TechWriter
Part-Timing Again
Posted: 10/06/22 01:27am Link  |  Quote  |  Print  |  Notify Moderator
If the campground has digital cable, your TV must have a QAM tuner.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
Posted: 10/06/22 04:19am Link  |  Quote  |  Print  |  Notify Moderator
There are three thigns
First is the TV set to CABLE or ANTENNA
second is the TV old enough to not undstandard Digital Cable
Third is the Cable signal "Encrypted'
Oh and 4: Element tv's... don't do digital cable at all. (only broadcast)
Last TV made in the USA and it only did NTSC and ATSC (Analog and digital brodcast) No QAM (Dicital cable).
Also if you are feeding the Park cable inlet on your RV.
1: TURN THE ANTENNA OFF (the wall plate with the switch, light, antenna connector and 12 volt outlet.. TURN IT OFF)
2nd: if someone re-wired for Sat TV you need to restore Factory config.
schlep1967
Harrisburg, PA
Posted: 10/06/22 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Start with this.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
MitchF150
Puyallup, WA
Posted: 10/06/22 09:22am Link  |  Quote  |  Print  |  Notify Moderator
He said he did that in his first post...
Other than checking the TV input settings and such, get a cable long enough to go from the post to the tv and plug it in directly. Then see what happens.
That will eliminate the RV's cabling setup and then you can go from there.
Good luck! Mitch
Posted: 10/06/22 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
And as I said ELEMENT TV's won't pick up Cable TV.
Also.... Some cable systems are encrypted. no STB (Set Top Box) NO TV
The one I'm watching now is that way.
