jerryleejr
TN
Ok, short version sold the house and went full time, did all the research set up a mail service etc, The DMV is not wanting to take it for my tag renewal. They need a physical residence within the county. Any ideas?
JJ
happynow
I used Good Sam Mail Service in Crestview FL.
No problems since 2015
happynow
Steve and Carol
Horsedoc
Dixie --- N. Georgia
Call the local DMV closest to where you lived in a stick and brick and explain the situation to a supervisor. She/he should be able to give you advice if you want to maintain same state for other reasons (insurance, license etc)
Southern California :(
Be up front with your auto/truck/RV insurance company.
phillyg
SWFL
If in FL you can set up your legal domicile in Bushnell using the Escapees services.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
arhayes
The Escapees website has a section with info on domicile issues. I’d check here https://escapees.com/?s=Domicile
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
johnhicks
Wandering below the Gnat Line
A mail service simply gives you a box, a Personal Mail Box, PMB. You couldn't reside in that PMB, so that address isn't a "real" residential address.
Some such as Escapees and St. Brendan's Isle can provide you a real address that you could live at, a domicile address. You would also become a legal resident of Texas or Florida for better or worse.
escapees.com
sbimailservice.com
-jbh-
Cptnvideo
Arizona - most of the time
A fulltimer that doesn't own property (land), can essentially choose any state as a residence. This is our 2nd time fulltiming and we remained AZ residents as we own a house in AZ that we rent out.
But the first time fulltiming, we chose South Dakota as our state of residence and went with a mail forwarding service there. Never had an issue with the SD DMV.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
ferndaleflyer
everywhere
My friend had the same problem in TN. He finally just gave up and did it through FL.
Michelle.S
Western NY till fall, then Sebring, FL
Here's what I have done to get around the PMB issues,
we use the Good Sam/PassPort America system in Crestview, so our address is:
5753 Hwy 85N
Suite xxxx
Crestview, FL 32536
By using Suite with your box number makes it good to go for most cases.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
