swimmer_spe
Sudbury, Ontario, Canada
2023 cherokee wolf pup 22bp
The heat is wonderful.... and not.
It has 2 outlets on either side of the kitchen cabinets. The problem is, with the door closed to the bedroom or bathroom, they get really cold. The doors have a bout a 2 inch gap at the top and bottom.
What do you do to get better heat in the various rooms?
QCMan
Independent Republic of Horry
Keep the doors open.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
swimmer_spe
QCMan wrote: Keep the doors open.
I am trying to avoid that.
dedmiston
Coast to Coast
Administrator
We put a little buddy heater in the bedroom with us.
Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
pianotuna
Regina, SK, Canada
Add a large grill in each door.
Regards, Don
Boon Docker
Get a cuddle bunny to keep you warm.
pbeverly
South Carolina
We like the bedroom cooler. We put a little heater in the bathroom.
Ridgeway, SC
"Heat up" the bedroom (Please use your lawfully wedded spouse to help heat).
Another blanket or a poem I once stuck in a box with an electric blanket I gave to a couple of newly weds (Wedding present)
You say our love will keep us warm
No matter how bad the winter storm
But if you're tired some hard day's night
An electric blanket will warm you right.
(Sounds almost like I should add "Burma Shave" as a new last line don't it?)
#1Flyboy
California
……. A good down comforter and then you can turn the heat OFF……..
Mayor30
Pa
If you can close the vents in the living room kitchen area, you can force more heat back to the bedroom.
