Cummins12V98
on the road
mobeewan wrote: bgum wrote: I need a qcc1 to qcc1 hose so I can fill a 5 pound tank from a 20 pound tank. Would a propane dealer be reasonably expected to make one?
As long as your cylinders each have the female POL thread this should work:
Propane transfer kit
Your link will only fill from standard tank to standard tank, not to small disposable tank.
On edit I can see you know that!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cptnvideo
Arizona - most of the time
Quite possibly a dumb question but bear with me.
We recently bought a Mr Heater propane heater and a 5' adapter hose to connect a 20# cylinder to it. After getting it back to the RV (fulltimers), I read the instructions which stated not to hook up a 20# cylinder indoors. Is this a CYA on their part or is it really dangerous to have the heater and 20# cylinder inside our RV. We wanted to run the Mr Heater overnight as they are much more efficient that the LP furnace and the 1 pound disposables only last 4.5 hours on the low setting.
By the way, years ago we had a Mr Heater Big Buddy in a 43' diesel pusher. I put a T in the gas line to the oven/stove and ran a hose to the Mr Heater. Never had an issue.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
Chum lee
Albuquerque, NM
Cptnvideo wrote: Quite possibly a dumb question but bear with me.
YES! It is DEFINITELY CYA, and also an attempt to minimize the chance that you BBQ yours.
From numerous widely published sources:
"All propane tanks, including the cylinders you use for your BBQ grill, are required by law to have pressure relief devices to allow for the release of excess pressure in the tank. A safety relief valve is there to protect your propane tank from rupturing if excess pressure builds up inside the tank."
Chum lee
Bobbo
Wherever I park
The concept is that a propane tank should not be indoors due to the possibility of a propane leak and a kaboom.
Bobbo and Lin
Tom_M
New Hope, MN
I removed the regulator from my Buddy heater then using a hose plumbed it to a tee in the line that feeds my cooktop.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
time2roll
By the way, years ago we had a Mr Heater Big Buddy in a 43' diesel pusher. I put a T in the gas line to the oven/stove and ran a hose to the Mr Heater. Never had an issue. There should not be significant high pressure propane or natural gas within the living space.
Not just fire but also Hypoxia hazard.
675w Solar pictures back up
Ray,IN
IN, USA
Bobbo wrote: IAMICHABOD wrote: A thread was closed before I could ask Grit Dog or anyone else about this. I have not heard of this here or anywhere else.
I carry This one for my small Weber Q,much easier to store and move.
I have never had a problem getting it filled. Are there some places that prohibit this and if so why.
Posted By: Grit dog on 10/08/22 09:19am
PS, that is the cutest little LP bottle I’ve ever seen! Good thing that guy don’t live in PA because he’d be stuck with no LP refills ….lol
That one is a standard propane cylinder just like a 20 pound or 30 pound cylinder, only in a smaller size. Your only limit is the same one that the 20# and 30# cylinders have, namely, they have to be recertified occasionally. The issue of refilling small cylinders that you hear about is refilling the little 1 pound disposable cylinders. They are not designed to be refilled, but some folks do so anyway.
Actually the law says "not to be resold if refilled".
2000 Winnebago Ultimate Freedom pushed by a 2013 Chevy Silverado K1500 And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
Bobbo
Wherever I park
Ray,IN wrote: Bobbo wrote: IAMICHABOD wrote: A thread was closed before I could ask Grit Dog or anyone else about this. I have not heard of this here or anywhere else.
You are talking law. I am talking original design criteria.
drsteve
Michigan
The little green bottles are single-use disposables because the valves are junk. Can you refill them? Sure. But if the valve fails, you may find yourself with a problem.
1991 Palomino Filly PUP
IAMICHABOD
Sunny So Cal
drsteve wrote: The little green bottles are single-use disposables because the valves are junk.
This is the very reason I went to the 1 Gallon that I linked in my OP.
More than once after I turned off my Weber and did not take the bottle off I would come back and it would be empty.One time I took one off and the valve didn't close up and the propane still was flowing. With the 1 Gallon when I turn it off I know it is off.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
