RV.Net Open Roads Forum: Tow Vehicles: EV charging quandry
Search only in Tow Vehicles
 > EV charging quandry
wanderingaimlessly
Garrison , Mt
Posted: 10/09/22 03:22pm Link  |  Print  |  Notify Moderator
Toed , the real fun part is,,,,,,,
If the response is only to the feasibility of the whole project, then all of Kali is out of excuses for its stupidity.
wanderingaimlessly
Garrison , Mt
Posted: 10/09/22 03:23pm Link  |  Print  |  Notify Moderator
BCSnob wrote:
If adoption of EVs will crash the grid, and a crashed grid would make conditions ripe for a civil war; why isn’t faux news promoting the adoption of EVs? [emoticon]
IT IS
shelbyfv
TN
Posted: 10/09/22 03:44pm Link  |  Print  |  Notify Moderator
"The top demographic of 2019 EV owners are
middle-aged white men earning more than $100,000
annually with a college degree or higher...." Another demographic summary showed 28% of EV owners had a Doctoral or professional degree and 35% earned over $200,000. What a bunch of losers, right? LMAOROFL
nickthehunter
Midwest
Posted: 10/09/22 05:31pm Link  |  Print  |  Notify Moderator
You done building that tsunami shelter yet Snob - fortify it well, it’s going to be a bigass wave.
nickthehunter
Midwest
Posted: 10/09/22 06:17pm Link  |  Print  |  Notify Moderator
Lwiddis wrote:
Keep guessing! Refueling ICEs in the very early days was done by buying gasoline in one gallon containers from a hardware store. Lead, follow or get out of the way. California chooses to lead.
Leads to what?
Good example of how CA leads
propchef
NORCAL
Posted: 10/09/22 06:38pm Link  |  Print  |  Notify Moderator
nickthehunter wrote:
Leads to what?
Did you highlight the part in purple? The author is incorrect. Here's the original 2008 plan from then-Gov Schwarzenegger's(R) administration for the High-Speed Rail. Note that the author of the article you quote is off by a decade in the original estimated 90% completion mark. It was originally scheduled to open in 2030, not 2020 as the article says. Also, note that they left out the fact that all of the numbers quoted were in 2008 dollars and not adjusted for inflation. Just another misleading article.
https://hsr.ca.gov/wp-content/uploads/docs/about/business_plans/BPlan_2008_FullRpt.pdf
The HS rail has spanned several administrations from both parties
NamMedevac 70
Reno
Posted: 10/09/22 08:05pm Link  |  Print  |  Notify Moderator
Well sno don't let your EV get submerged in salt water as they are exploding in many areas of Florida after Ian according to Fire Departments. Ev fires take between 3 and 8 thousand gallons of water to put out and as long as 4 hours to extinguish whereas ICE fires take about 1000 gallons of water. Sometimes later the EVs catch fire again.
Many EV owners have returned to ICE vehicles as EVs not practical, and many other EV owners still have ICE vehicles as good solid backup. EVs are much heavier than their ICE counterparts. A Hummer EV battery weighs almost 3000 lbs in the 9000lb hummer.
Head of Toyota motor company said California mandate of 2035 will not happen and toyota sells the most cars in kalifornia. The Gov was just sounding off for his choir. Business news is your friend if you are not low energy.
* This post was edited 10/09/22 08:36pm by NamMedevac 70 *
