RV.Net Open Roads Forum: General RVing Issues: Winter Battery Storage
 > Winter Battery Storage
pianotuna
Regina, SK, Canada
Posted: 10/26/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
The colder it is the less the self discharge. So bringing it inside creates the need to recharge.
Personally the solar charger works well for me.
Regards, Don
JKJavelin
Milwaukee, WI
Posted: 10/27/22 06:52am Link  |  Quote  |  Print  |  Notify Moderator
dedmiston wrote:
dapperdan wrote:
I had 300 watts on our previous trailer and now 660 watts of solar on our current trailer, haven’t taken the batteries out since the solar went in! I haven’t had a battery issue yet, the solar keeps the batteries “full”, no freezing. Here in WI it can get below zero, maybe not as cold as Minnesota but cold none the less. [emoticon]
Dan
Hey Dan - Question about your solar. We store our rig in the southwest where I worry about dust and crud covering up our panels (700W), but we get enough rain in the cooler months to hose them off.
What do you do in Wisconsin with the snow? Does the snow accumulate and cover your panels?
We sure love having the batteries charged and ready to go 24/7/365.
I also am in southeastern Wisconsin. Where I store mine, the wind blows most of the snow off of the roof. Then, if you get a sunny day, the black solar panels warm up a little and the snow will melt off of them.
I've had the solar for 2 winters so far, (we don't head south until late January) and it's been fine.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde AllTrek 4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 106 Nights
pianotuna
Regina, SK, Canada
Posted: 10/27/22 07:58am Link  |  Quote  |  Print  |  Notify Moderator
dedmiston only once have I had to clear the panels since 2009.
Even then, there were 17 amp-hours going into the battery bank on Dec 21.
Cummins12V98
on the road
Posted: 10/27/22 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Three seasons on the boat batteries with just disconnecting the grounds and winder temp into the single digits. Same goes for my 01 RAM. They both fire off the engines with reconnecting the grounds.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
PA12DRVR
Back in God's Country
Posted: 10/27/22 10:05am Link  |  Quote  |  Print  |  Notify Moderator
FWIW...
....my power toys primarily live in Los Anchorage. Typical winter sees regular below 0 (F) temps, frequent below -10, and often quite a few days of -20.
....For the boat and the OR Jeep and the summer ATV, I pull the batteries and put them inside; fully charged in circa October / November; trickle charged to full charge about 1x per month after that until "spring" which realistically means mid-May.
....For the spare road vehicles, I typically end up moving them around the driveway at least 1 x per month, so nothing special is done to the batteries, although I make sure the engine runs at least 45 mins during that 1x per month.
....For the PA-12 and the sno-go; trickle charge about 1x per month if not otherwise used; on the infrequent trip to cold country (where -30 is common, -50 is not unheard of), I pull the batteries every night and bring them in the tent/cabin, etc. Particularly when flying the PA-12 somewhere cold, if it doesn't start one is either faced with a very serious situation or faced with the need to hand prop...a very serious PITA.
My batteries typically last at least 8-10 years, but they're all automotive, not golf cart.
CRL
My RV is a 1946 PA-12
Back in the GWN
Goostoff
Wisconsin
Posted: 10/27/22 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just leave my trailer plugged in year round. Last battery survived 10 years. It is quite common to see -30F here in the winter
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Boon Docker
Posted: 10/28/22 11:03am Link  |  Quote  |  Print  |  Notify Moderator
My batteries (disconnected) sit outside all winter in -20C temp and they are going into their 10th year.
Cummins12V98
on the road
Posted: 10/28/22 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Same arguments about covering tires. I have never done so and never had a crack. Same with using 303, never have.
No matter the subject you can get all twisted around!
