RV.Net Open Roads Forum: Tech Issues: Proper Accumulator Tank Pressure
 > Proper Accumulator Tank Pressure
Gdetrailer
PA
Posted: 10/11/22 11:10am Link  |  Quote  |  Print  |  Notify Moderator
egarant wrote:
I read the manual, I even quoted the one part of the manual that I had a question on....is the RESTART pressure the same as the Turn on Pressure?
That's all.....
There is no such thing as "restart pressure" in water systems.
You have turn on (IE the "lowest" pressure) and turn off (IE the "highest" pressure).
Pump will only "turn on" when the pressure is less or equal to the turn on pressure.
Pump will "turn off" when the pressure reaches the highest pressure and will not turn back on until the pressure falls to or below the turn on pressure.. The pump will not turn on (or "restart" as you put it) until the pressure is equal to or less than the turn on pressure.
So your pressure tank precharge in order to make the system work correctly SHOULD be set no higher than the TURN ON pressure.
The precharge pressure however can be less than the turn on pressure to a certain extent and still work fine. The well driller that I had in to replace my home well pump and pressure tank yrs ago actually sets the precharge 2 PSI below the turn on pressure.. Not sure exactly why, but it works fine, the guy does that for a living so he must have some reasoning for doing it that way.
To be clear, turn on is the lowest pressure.
Pump will not turn on between the turn off and turn on after it has been tripped to off until pressure drops to or below the turn on pressure..
You do not want the precharge to be higher than the turn on, otherwise, why bother with the pressure tank?
Turn off is the highest pressure.
ScottG
Bothell Wa.
Posted: 10/11/22 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Dutch_12078 wrote:
ScottG wrote:
Mr. E, please let us know how this works out for you. I have the same pump and have been considering adding an accumulator to smooth out flow but not sure how it will work with these bypass pumps. (Manufacturer just says "not needed").
The accumulator will work ok with a bypass pump. The manufacturer is correct that it's not needed for the low flow pump cycling that occurs with non-bypass pumps, but it still works well for cutting down on how often the pump runs. I have a 2-gallon accumulator installed with a SHURflo Revolution bypass pump, and we can often make it through the night with typical old folks bathroom visits without the pump running at all.
Good info - thx! What did you set the tank pressure to?
C Schomer
Pueblo West, Co.
Posted: 10/11/22 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
The reasons for -2 DP and 0 DP are in my previous post. Setting the pressure at zero or slightly less all depends on how fussy you want to get. Zero will give you the maximum draw down and -2 will allow for slight pressure switch variations and make sure the pump always cycles the way it should. You just have to outsmart your bladder!! Haha!
Vintage465
Prunedale CA.
Posted: 10/11/22 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
I pumped mine up to 40psig to go with a 55 psig pump/system. And I didn't really think it all that easy to connect the dots in the manual........
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
egarant
Mission Viejo CA
Posted: 10/13/22 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Well I called Shurflo today, hard to find their number, but it's 1-800-834-3218, keep it in your phone.
According to the tech, if you have the 4008 pump, as stated the turn on pressure is not the re-start presure and he didn't know why the manual for the pump doesn't clearly state it.
The turn on pressure for that pump is 38 psi, so the accumulator pressure should be set at 38 psi.
I think someone did come to that same conclusion, but I thought I'd double check.
Cheers,
Mr. E
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 3K VictronConnect Multiplus II, VictronConnect smart DC-DC charger, VictronConnect 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
