RV.Net Open Roads Forum: Tech Issues: No water pump
 > No water pump
Silas Carpy
Elmira N.Y.
Posted: 10/10/22 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Began winterizing today. Same process as last year. Opened tank and low point drains. Drained water heater. Removed filter, closed w.h. bypass valve, closed tank and low point drain valves. Dumped 5 gal af into tank. Started pump, ran for a few seconds as usual and stopped. Went outside to turn on o.s. shower, nothin. Went back in, pump off. Turned it back on and now have no pump. Fuse good, pump switch light comes on but no pump whatsoever. Any ideas? Thank you. 2009 Fleetwood Pulse, sureflo pump.
CA Traveler
The Western States
Posted: 10/10/22 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Measure the voltage at the pump. Could be pressure switch, can you bypass it?
2014 Grand Cherokee Overland
Bob
enblethen
Moses Lake, WA
Posted: 10/10/22 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
If you have multiple places to turn pump on/off, try another switch location. Could indicate failed pump controller.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
schlep1967
Harrisburg, PA
Posted: 10/11/22 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Try changing the level of the trailer. You may not have enough fluid in the tank to allow it to get to the drain.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
jkwilson
Indiana
Posted: 10/11/22 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried opening a different faucet?
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Roger10378
Goodrich, MI.
Posted: 10/11/22 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Is the outside shower head on as well as the faucet?
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
way2roll
Wilmington NC
Posted: 10/11/22 08:00am Link  |  Quote  |  Print  |  Notify Moderator
My guess would be there isn't enough fluid in the tank to prime the pump. Either add another 5 gals to the tank or rig up a siphon to a jug directly at the pump to pull it into the system.
2023 FR Sunseeker 2400B MBS
Silas Carpy
Elmira N.Y.
Posted: 10/11/22 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Pump under bed, couldn’t reach, had to remove board it is mounted to to access from cubby. Bypassed pressure switch, pump runs, much quieter than before, does not shut off but still no af coming out of any faucet. Rv is level, both pump switches work to turn pump on. I do see a drip coming from pump when on. From pressure switch being bypassed?
schlep1967
Harrisburg, PA
Posted: 10/11/22 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Add a board under one side of the RV wheels. Water tanks tend to sag in the middle and pickups are generally towards one end or the other. Lifting one side will push antifreeze toward the other end. All you need to do is figure out which end the pickup is on.
MFL
Midwest
Posted: 10/11/22 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what is going on with the pump? I would suggest, while having access, to add a winterizing kit, for this process, rather than adding AF to the fresh tank. It takes a while to clear that AF from the tank, when needing to use water again. After a couple of AF laced showers, it usually clears out!
Jerry
 > No water pump
