RV.Net Open Roads Forum: Travel Trailers: Trailer Brakes HOT after adjustment
 > Trailer Brakes HOT after adjustment
Baja Man
Inland Empire, CA
Posted: 10/10/22 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all-
Recently completed a bearing pack, bearing seal replacement, and brake adjustment. I can't imaging the heat being caused by the bearing grease packing.
Hub adjustment:
Hubs were tightened, then loosened a little so that wheel spun freely and there was no play in hub when moved in/out.
Brake adjustment included:
Backed out shoes from adjustment port to where the brakes locked up. Then backed out about 5-7 clicks to where there was a mild scrape/sound feel.
I tested brakes by driving around under tow for approx. 5-10 miles braking hard and also using my Tekonsha brake lever to brake hard (not at the same time). I did hard braking doing 30-40mph. I did this to adjust my Tekonsha gain setting and to be sure brakes did not lock up on a hard stop.
After the drive, I pulled over near my home and went back to touch brake drums. They were very hot to the touch...all 4.
Can the slight drag from adjustment be the cause of the excessive heat?
Is it from the hard braking several times?
If drums are hot from not adjusted properly (tad too open), would the 5-10 miles of hard braking and hot drums have caused damage to anything?
Thanks!
* This post was edited 10/10/22 07:31pm by Baja Man *
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 Trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
BB_TX
McKinney, Texas
Posted: 10/10/22 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I always backed mine off until no drag or scrape sound at all and wheel spun freely.
* This post was edited 10/10/22 07:59pm by BB_TX *
Baja Man
Inland Empire, CA
Posted: 10/10/22 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
That was my first thought......I'll re-adjust with no rub and drive test it again
....wonder if any damage occurred?
bucky
Raleigh metro
Posted: 10/11/22 03:57am Link  |  Quote  |  Print  |  Notify Moderator
After that hard braking it's not surprising that they were hot. No different than your car or truck after repeated hard braking.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
MFL
Midwest
Posted: 10/11/22 06:04am Link  |  Quote  |  Print  |  Notify Moderator
I don't think any damage, and likely drums were hot from applying brakes repeatedly.
I normally can hear a slight drag after adjusting brakes. As to turns backed out, MINE usually amounts to 3-5 turns out, from a setting of hard to turn wheel, with one hand. Turns out can vary, one trailer to the next, but I go by how easily the tire/wheel spins, for correct adjustment. With a light spin of wheel, I like to see it rotate about one and a half turns before stopping.
With your wheel in the air, grab it at 3 o'clock and 9, try to make it wobble. A barely noticeable wiggle is good. Now give it a light spin, how many revolutions does it go before stopping on it's own? I like to see more than one turn, but more than 2 turns, means there is no drag.
Jerry
MitchF150
Puyallup, WA
Posted: 10/11/22 09:01am Link  |  Quote  |  Print  |  Notify Moderator
I know if I did this with mine, they would all be hot?
If you drive around without hitting the brakes that much or hard on the trailer, how hot are then then?
Unless I missed something in your post?
Mitch
klutchdust
Orange, California
Posted: 10/11/22 10:31am Link  |  Quote  |  Print  |  Notify Moderator
I carry one in my tow vehicle. Check things when taking a break, stretching the new knee. It takes the guesswork out . What was your tow vehicle like?
Baja Man
Inland Empire, CA
Posted: 10/11/22 11:31am Link  |  Quote  |  Print  |  Notify Moderator
I did not check temps with a temp gun.
Truck brakes work fine and trailer towed and stopped well.
I did not check temps under normal use (without hard braking).
Should wheel be turned and spin freely with NO brake shoe even barely touching?
I know brake adjustment may be by feel, but I want to be sure there is no brake dragging and/or premature shoe wearing. How can I adjust accordingly....just barely scraping or spin freely?
Krusty
Calgary, Alberta,Canada
Posted: 10/11/22 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I always adjust mine to the point that I feel light drag. I think the heat you felt was just from the hard braking. If it makes you feel better, take it for another drive without the hard braking and recheck the temp
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
WayneAt63044
St. Louis, MO
Posted: 10/11/22 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
For a while I had some self-adjusting and some manual adjust brakes. The self-adjusting drums would measure 120 degrees while the manuals were around 90 degrees after a 2 hour run. I since have gone to all manual adjust brakes to keep the temperatures down. You really don't want to adjust them to rub a bit like the self-adjusting always do.
To test bearings & braking I would jack up one wheel at a time and check for just a very slight wobble in the bearing and then pull the emergency brake cable to engage the brakes. Then spin the wheel forward to determine how far it rotates with the magnet energized before the brakes apply. Never got over 1/2 turn before the brake shoes stopped rotation by hand.
No need to have things so tight you get unneeded friction and heat.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
