RV.Net Open Roads Forum: Travel Trailers: Trailer Brakes HOT after adjustment
 > Trailer Brakes HOT after adjustment
Posted: 10/11/22 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Go do the same routine and timing with just your car or truck and stick your finger on the rotor. If you burn your finger, your trailer brakes are fine. If you don't then they may need backed off a tad, especially since you need to be economical with your brake linings.
dedmiston
Coast to Coast
Administrator
Posted: 10/11/22 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Don't do that. ^
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Baja Man
Inland Empire, CA
Posted: 10/11/22 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Did anther run today...
About the same ambient temps...78F
5-10 miles with normal braking.
ALL 4 drums (and measured at each shoe area - 9 o'clock and 3 o'clock) were between 92F-93F except for one shoe area on one wheel. The secondary shoe (3 o'clock position) on right rear wheel measured 99F-100F
NOTE: They were all warm to the touch, but no where near as hot as yesterday.
Thoughts?
2023 GMC, 3500HD, Crew Cab, 6.6L Gas/6 Speed Auto, 4X4, Standard Bed; SRW
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
12th Man Fan
Flower Mound , Texas
Posted: 10/11/22 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I think you are good to go. the heat was from excessive braking and I would not worry about a 7 degree difference. I think the slight rubbing you was hearing was the magnets and not the brake shoes.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Huntindog
Phoenix AZ
Posted: 10/11/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Just a thought... A post like this really needs an emoji, such as [emoticon][emoticon][emoticon] etc. just to let people know it is a joke....
It is a joke right?
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
opnspaces
San Diego Ca
Posted: 10/11/22 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thoughts?
I would put the temperature gun away you are over thinking this. Seriously though, there are many things that can cause a slight difference in temperature between drums. 5 degrees is nothing. 50 degrees maybe start to worry a bit.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
