huskyfan68
usa
so I wasn't thinking over the weekend- I had my gray tank valve closed and my outdoor kitchen sink somehow backed up (which i was not using)-
Short story- the sink overflowed and the water went under cabinet and got some of the insulation (and prob) the wood wet- I have limited access to this area- I took off the panel so i can see the plumbing under the sink. Need recommendations on what i can put in that area to get rid of as much moisture as possible- I am sure I can buy stuff from Lowes that absorb moisture but looking for other suggestions since it is a hard area to access
bgum
South Louisiana
Dehumidifier and close up rig while running.
Tyler0215
Iowa
pull up the vinal floor covering under the cabinet to allow the underfloor to dry. You may need to take down the coraplast cover and insulation from under the trailer if it is wet you will never get it dry from inside.
