RV.Net Open Roads Forum: Fifth-Wheels: heavier trailer tires and fuel economy
 > heavier trailer tires and fuel economy
johndeerefarmer
Posted: 10/11/22 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I know heavier tires on your truck decrease fuel economy but what about on a trailer? Looks like once you get it up to highway speed it wouldn't matter?
why I asked was I got tired of the blowouts on the 12 ply junk and put some heavy 14 ply on my trailer. Wondering if and how much mpg will be affected
Thanks
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflection 29rs
Tyler0215
Iowa
Posted: 10/11/22 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Not enough to measure.
spoon059
Just north of D.C.
Posted: 10/11/22 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, there will be some effect. Like Typer0215 stated, it is likely small enough not to worry about. Perhaps the heavier weight and stiffer sidewall will provide less flex in the tire, making it have less rolling resistance anyways. The comfort of knowing you have plenty of available weight carrying capacity makes me happy, even at the potential cost of slightly less fuel economy.
2015 Ram CTD
2015 Jayco 29QBS
StirCrazy
Kamloops, BC, Canada
Posted: 10/11/22 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
it will effect it a tiny bit, the physical size has more effect than a small shift in weight. you could also see if there is one that is "energy conserving" or have a lower rooling resistance. this and how tight you pack wheel berrings and set your brakes have a larger effect than just a little bit more weight.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
stickdog
Somewhere, USA
Posted: 10/11/22 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
You paid for more tires it shouldn't bother you to pay a little more for the safety they provide.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
time2roll
Posted: 10/11/22 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Assuming the new tires run at higher pressure... I believe the fuel economy is more likely to increase.
Best if the tire load rating covers the entire trailer GVWR.
675w Solar pictures back up
joshuajim
Mojave Desert
Posted: 10/11/22 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
It’s pretty well known fact that trucks that switch from lighter P tires to heavier LT tires always lose on mileage. Is it the heavier tire,the stiffness of the tire or tread pattern. Who knows.
RVing since 1995.
HTElectrical
Las Vegas
Posted: 10/11/22 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Rotating mass robbs horsepower.
2007 Duramax, Cognito 7"-9" Lift,
rhagfo
Portland, OR
Posted: 10/11/22 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
______________________________________________
GD Reflection 29rs
If you are referring to the 5th wheel in your signature, get a good set of LT tires, and skip crappy ST tires. I run Yokohama LT 235/85-16E tire on our 12,360# GVWR 5th wheel. Your 5th wheel has a GVWR of 10,000#, the LT are more than enough tire for it.
eHoefler
ozark mountains
Posted: 10/12/22 05:06am Link  |  Quote  |  Print  |  Notify Moderator
I run 17.5 MT tires rated for 6005 pounds per tire and wheel combination on my fifth wheel, wheels weigh 60 pounds each, with tires weighing 65+ pounds. I run them at max psi of 125. Actually get better mileage than the 16" tires they replaced.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
