RV.Net Open Roads Forum: Travel Trailers: Smaller tanks
 > Smaller tanks
LITEPHIL
AZ
Posted: 10/12/22 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone gone from the 33 lb tanks down to the smaller 20 lb tanks? It's so easy to just swap the smaller ones out at just about anywhere.
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
opnspaces
San Diego Ca
Posted: 10/12/22 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I have not but it should be an easy swap. The only things i see as a possible stumbling block is the length of the pigtails might require you to remount them lower. Also you might have to do some work to adjust the hold down bracket. But other than that they should work fine.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
mleekamp
Washington, IL
Posted: 10/12/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
You could also carry 1 extra 20lb tank for just such a need. Instead of replacing the 33's, use a 20 and a 33, and replace the 20 as needed.
I don't know, there are many ways to do it. Years ago, on our Salem TT, we had 2 - 20's since new. I added a third to storage, and could rotate out as needed. Different, but just a thought.
2112
Posted: 10/12/22 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
I'm considering it after my two 30's expire next year. One 30 pounder lasts us over a year.
2013 KZ Durango 2857
valhalla360
No paticular place.
Posted: 10/13/22 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Our current rig came with 20# tanks. Even in cold weather, we typically get a month or more on a tank.
We do usually get them filled. By filling, you get 20# of propane instead of the swap places that typically give you 15# of propane in a 20# bottle. And the fill is typically cheaper than the swap.
The exception is when a tank ages out. Then we swap for a newer tank and go back to filling.
The supports might require some minor modifications but shouldn't be anything complicated or expensive.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
ktmrfs
Portland, Oregon
Posted: 10/13/22 10:58am Link  |  Quote  |  Print  |  Notify Moderator
recently I filled a 30lb tank cost was less than a 20lb tank swap and the tank swaps you get aren't even filled to allowed capacity, They underfill. Basically double the propane for less money.
2011 Keystone Outback 295RE
LITEPHIL
AZ
Posted: 10/16/22 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I guess I'll stay with the larger tanks for now. I had one empty and when I filled it, I had him stop at 6.8 gal and it was $28.00. I went all summer with around 5 trips 4 or 5 days long on one tank. One tank lasted a pretty long time.
APT
SE Michigan
Posted: 10/16/22 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I use one tank at a time. When one is empty, I switch and refill before the next trip. That has always been enough time to find a cheaper filling location.
2017 Subaru Outback 3.6R
2020 Chevrolet Bolt
Bmach
Western MA.
Posted: 10/19/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Save yourself some money just get your tanks recertified. Way cheaper than buying new tanks.
p38fln
Superior, WI
Posted: 10/26/22 09:23am Link  |  Quote  |  Print  |  Notify Moderator
How do yo get 30# tanks certified? Ours are from 1990. We've mostly been using 20# tanks but when it gets below freezing the camper can easily burn a tank a day.
 > Smaller tanks
