wallaceb
Sussex new Jersey
Good Morning Forum, I own a 2022 Nash 18FM that came with a Zamp Solar Controller system for my two solar panals. Zamp controllers are new to me. I am getting ready to store the unit for winter for the first time. I will remove and store the AGM battery BUT I am not sure how to "shut down" the controller as the trailer will be under ADCO cover for the winter. I contacted Zamp and obtained the Operators Manual but I don't find info on how to turn the system off and winter storage of same. Any guidance would be appreciated.....Thanks un advance, Wallace B
Ed_Gee
Central Oregon coast
I have never seen the need to 'turn off' the Zamp solar charge controller in our RV for storage. Why would one want to?
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
bgum
South Louisiana
It has been said that with nothing to charge the panels don't do anything.
2oldman
NM
Under cover the panels will do nothing, but, since the recommended connection sequence is batteries first, I think I'd disconnect the panels from the controller.
ktmrfs
Portland, Oregon
2oldman wrote: Under cover the panels will do nothing, but, since the recommended connection sequence is batteries first, I think I'd disconnect the panels from the controller.
Not true on the "under cover panels will do nothing". Under my ADCO cover and another cover my panels will still give a few amps on sunny days. The reason is that most covers allow some light spectrum through that the panels respond to. Just because us humans can't see through something doesn't mean certain light wavelengths are blocked. An example is the black plastic on entertainment stuff. transparent to Ir but blocks visible light.
2011 Keystone Outback 295RE
2oldman
NM
ktmrfs wrote: Not true on the "under cover panels will do nothing". Then he better disconnect them.
My panels are under the cover of a metal roof and the controller says nothing is happening.
Ed_Gee
If you contacted Zamp already, why didn't you ask them? They have excellent customer service . Just a phone call away. Frankly, as I already said, never an issue for me in past years to leave Zamp as is. there is no off switch. Additional, with battery disconnect switch off, no need to remove batteries anyway . The Zamp controller bypasses that switch and will continue to keep batteries topped up, even with a cover over them.
Southern California :(
WindyNation says…”WARNING: Connect the battery BEFORE connecting the solar panel(s).
1) Connect the Battery Connect the charge controller to the battery BEFORE connecting the solar panels to the charge controller.”
I’d disconnect the panels from the controller first if you are planning to remove the batteries.
ktmrfs
Portland, Oregon
2oldman wrote: ktmrfs wrote: Not true on the "under cover panels will do nothing". Then he better disconnect them.
metal roof, yes, but under a typical woven cover my experience along with several others is that a 150watt panel will give about 1A under clear sky in the winter. The woven fabric covers are not completely blocking all the wavelengths of light the panels can respond to.
pianotuna
Regina, SK, Canada
disconnect the panels from the controller. Then disconnect the batteries from the controller. Doing it in any other order may let out the magic blue smoke.
Regards, Don
