way2roll
Wilmington NC
Need new tires on my F350 as the OEM's have worn out. So I am shopping tires where we usually get them but that's always been passenger vehicles without any concern about load rating. So I call them up and tell them what I need - 275/70/18's with an E load rating. Guy tells me they have Michelin defenders (good tires, my wife has them on our CRV) but he seems confused about load rating. He said they are an R rating. I said that's rotation/speed not load. He tells me they are rated for 3,000 lbs. That sounds beefier than an E rated tire and I have concerns about harsh ride? He went into some spiel about how the quality of the rubber really matters more than load and sidewall flex. I was like , "Huh"? Anyway, the load rating seemed elusive to him and his price was $323/tire which seems high. I think the obvious choice is to call around, but this dude who is normally great about anything cars, seemed confused about truck tires. Or am I?
2023 FR Sunseeker 2400B MBS
Not sure who is confused more. Tire guy or you.
First, it's just too hard to look at your current tires and see the load rating, or use the internet, I guess?
275-70-18 E is a common OE size they are (all) 125 load rating or 3638lbs rated.
How soft or harsh a tire rides is 90-95% air pressure and very little to do with it's load rating or treadlife.
Price for the tire you picked out is not horrible. Online they're about $280-$310. Again something you can find out yourself pretty easy with the ole googler or calling other tire shops.
Southern California :(
IMO find another tire store.
Fisherman
Angus, Ontario, Canada
No, he needs to read about tire specs (with a pair of spectacles). QRSTUV...Z are speed ratings, Load ratings are usually CDE and F. E load rating is around 3000lbs.
BarryG20
Castle Rock, Colorado
Well I would say 3000lbs for that size in E load is a bit short should be more like 3680. And in fact the Michelin Defender m/s tire in that size is 3680lbs @ 80psi with a speed rating of R (106 mph). I would suspect that if you looked up your oem tires you would find the same perhaps different speed rating
You are not confused he is and if you hadn't used them in the past I would be moving along to the next salesperson or tire store. I personally am not sure I could hold a straight face or not make some sort of snarky comment while walking out the door based on his comments about rubber quality vs load rating. Both are important but doesn't matter how high of quality the rubber is if it cant handle the load.
I am looking at new tires as well and was also surprised at the cost, they have certainly gone up since my last set about 2 years ago. My tire needs are probably different than yours but looking at some Goodyear Wrangler Duratracs same size and load range are in that range. However at Tire rack those duratracs are 338ea those michelins I looked up are 281ea. so I would say it may be worth your while to shop around and or at the least find a more competent salesperson.
2016 Jayco 28.5 RLTS
shelbyfv
TN
Check this Defender LTX
Turtle n Peeps
California
Hard to say from your post but it looks like the guy was trying to sell you P tires for your truck. That would be my guess but it's only a guess.
">&s_kwcid=AL!3756!3!354820920374!b!!g!!........ds]You can read about load ratings here.
Maybe the above link will help you. They do have an RF tire which is just a beefed up P tire. But as you can see, the LT tires only go up to an F tire which is a 12 ply tire.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
BB_TX
McKinney, Texas
Agree with Barry that the Michelin Defender E are rated for 3,680 lbs. Those are what I ran on both my F350s except mine were 20”.
Retired JSO
North Georgia Mountains
I have found my local Automotive dealer, Ford or Chevrolet can meet or beat any price you get from tire dealers like Discount Tire. My Chevrolet dealer got my Yukon 22” OEM tires for less than local stores and our Atlanta, Discount Tire + got me a $100 rebate.
way2roll
Wilmington NC
Thanks for all the replies. I called a few places and did some research and the Michelin defenders seem to be what I'm after. My shop has that tire for $1300 out the door which seems like a good price. They do my oil changes and free rotations so that's a bonus. They just really threw me with some of the conversation. Thanks!
