notsobigjoe
southeast
Reality Check wrote: Baja Man wrote:
How can this be solved?
What others done with this dilemma?
Spend more money than he was planning.
Unless the trailer is tiny, tiny and super light tongue weight...36" out is massive for 2" only.
Super hitch is where just about everyone ends up...even those of us that weld and fabricate.
I would think the class three hitch would be a problem as well. I do not think it's designed for that kind of up and down tork.
vern kelly
la crescenta, ca
Baja Man,
I have a custom overlap welded extension that was custom made by an RV Lance dealer so I could tow my boat with the camper on. He asked what type of boat I had, as tongue and tow ratings are reduced with the extension.
Originally the Dodge was Class III but I upgraded to Class IV when I towed horse trailers without the camper a few years ago.
The first tube goes in the truck receiver and the other piece is welded onto that piece with quite an overlap and just clears the rear bumper of the camper. My hitch then plugs into this end with the proper drop to tow level. Test your tongue weight of the boat.( My 18 foot bow rider is under 100 lbs). A simple wiring extension is used. I do reinforce the connection with taught safety chains and inspect before each use. Been using for 24 years and stored in a dry garage.
A bonus of the extension is I usually remove the camper at the camp site and leave the extension on the truck when launching, which allows no rear wheel submersion on even shallow entry ramps.
1998 2500 Dodge V10 3.55 Quad cab. Lance 5000 camper 9'10" and tow 17.5 ft Larson Boat
KKELLER14K
BEAVERTON OREGON
This is an example of my setup. Class 5 hitch 41" stinger. Cinched down to take out the extra movement.
![[image]](https://i.imgur.com/NrkCFMZl.jpg)
![[image]](https://i.imgur.com/t5qIrz9l.jpg)
wnjj
Cornelius, Oregon
No need for the extension to reach from inside the receiver to the back of the bumper. I use an 18” extension with an extended ball mount to pull a cargo trailer behind a 9.5’ camper. With a boat trailer you will likely not even need the extended ball mount.
Baja Man
Inland Empire, CA
Pontoon boat is 3500# with approx. 350# of TW.
We decided on the Torklift Super Hitch and Super Truss 36".
The reason we considered the 36" extension on a 2" receiver, is because that was what was on the previous owner's truck which had this camper on it. It was not a Super Hitch. He towed a 2 horse trailer for many years. I suspected it may not be correct because of the distance between the hitch ball and the fulcrum point .....
Not knowing what was correct and safe, is why I came to this site to ask.
YES, Grit Dog, I will be helping my friend with this project. Not sure why you thought I shouldn't?
Now, to see how many holes line up between old hitch and new hitch. Old has 3 bolts each side and new has 5.
Thanks for the assistance!
Preparing to sharpen some 1/2" bits!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 Trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
jimh406
Western MT
Baja Man wrote: Pontoon boat is 3500# with approx. 350# of TW.
Good choice and good to have sharp bits!
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
mkirsch
Rochester, NY
Good choice on the receiver but I think you may come to find out that the extension is going to be at least 12" too long. Hopefully they will let you trade down to the shorter one.
jaycocreek
Idaho
That's weird,I have a 1994 ford f350 drw and a 9.6 Lance and a Reese 18" extension works perfect..That S&S must be longer than 9.5..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
mkirsch wrote: Good choice on the receiver but I think you may come to find out that the extension is going to be at least 12" too long. Hopefully they will let you trade down to the shorter one.
He only reads what he wants to hear...
Hence part of my initial response to the query.
BigSwick
FL
Curious to how much weight the Supertruss adds with the extension over stock hitch? (and therefore decreases your "legal" camper carrying capacity?)
it must be significant.
