Reality Check
North Bend
BigSwick wrote: Curious to how much weight the Supertruss adds with the extension over stock hitch? (and therefore decreases your "legal" camper carrying capacity?)
it must be significant.
It's beefy, but not that heavy. If someone is that close on capacity, they have other issues. And towing anything probably shouldn't be on the menu.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
Baja Man
Inland Empire, CA
jaycocreek wrote: That's weird,I have a 1994 ford f350 drw and a 9.6 Lance and a Reese 18" extension works perfect..That S&S must be longer than 9.5..
Do you have a rear camper bumper?
From his receiver collar to edge of camper bumper is 29".
His steel rear camper bumper is 11" deep. If he didn't have the bumper, an 18" extension would work.
edited 10/19/22 07:34pm by Baja Man *
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 Trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
jaycocreek
Idaho
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
mkirsch
Rochester, NY
Baja Man wrote: From his receiver collar to edge of camper bumper is 29".
You missed the point. The extension does not have to go all the way to the rear edge of the bumper.
An 18" extension will put it 11" under the bumper. A standard shank will add a minimum of 6" to that and put the ball a mere 4" under the bumper of the camper.
I know, I'm probably beating my head against the wall on this, but I already have a headache so it's no big deal, LOL.
mkirsch wrote: Baja Man wrote: From his receiver collar to edge of camper bumper is 29".
You probably are…lol. Take a couple Tylenol and take a stab at getting him to understand, tomorrow maybe.
BigSwick
FL
Reality Check wrote: BigSwick wrote: Curious to how much weight the Supertruss adds with the extension over stock hitch? (and therefore decreases your "legal" camper carrying capacity?)
After some net searching, I estimate that for my application, the hitch itself would add about 30 pounds over the stock hitch. A 36" extension adds about 70 pounds. If towing a 3500 pound trailer, there should be about 350 pounds of tongue weight. All the above reduce the carrying capacity you can put in the bed (your camper). If you have a 4500 or 5500 series truck, it probably won't be a factor. If you have a 2500 or 3500 series truck, you should take notice..
^ O. M. G.
Baja Man
Inland Empire, CA
ticki2 wrote: I think the OP said the measurement was from the hitch to the outside of the bumper .
Exactly!
Baja Man
Inland Empire, CA
My friends set up is very similar...he has a camper bumper that adds distance between hitch and rear edge of bumper.
Baja Man
Inland Empire, CA
I do understand about perhaps not needing a 36" extension. The boat coupler would be too close to bottom of camper bumper with less than 36". My friend does not want the ball connection under the camper bumper. Concern would be up driveways at angles that are steep could cause trailer coupler/tongue to hit camper bumper. Plus, the added length will assist when launching boat.
Grit dog.....I do read all that are assisting in productive manners.....not just what I want to hear!! Your responses are not always productive. All other responses are appreciated and have been productive.
edited 10/27/22 07:17pm by Baja Man *
