RV.Net Open Roads Forum: 36" Hitch Extension for 2" Receiver - Are they Made?
 > 36" Hitch Extension for 2" Receiver - Are they Made?
Page of 5
Baja Man
Inland Empire, CA
Posted: 10/27/22 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to share a couple of pics of the TL Super Truss 36" LOWER support bar. The 5/8" hitch pin hole was drilled incorrectly. The hitch pin hole was approximately 5/16" off center on one side.
This is poor quality control and should be embarassing for TL. Contacted them and sent pics. Awaiting a response.
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 Trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
notsobigjoe
southeast
Posted: 10/27/22 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that's ridiculous!
jimh406
Western MT
Posted: 10/27/22 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
I think the tubes can move independently. Maybe it got bumped in shipping if I'm right.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Baja Man
Inland Empire, CA
Posted: 10/27/22 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
The tubes are separate pieces. The lower tube inserts into the lower receiver hole where you then line up holes and insert 5/8" pin. It is the lower tube that was not drilled correctly.
jimh406
Western MT
Posted: 10/27/22 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
That aligns with what I was thinking, but if you loosen the straps, can you not get enough play to align the lower pin? Then, tighten the straps that hold the tubes together.
Baja Man
Inland Empire, CA
Posted: 10/27/22 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
We never even connected the two tubes together. We simple inserted the lower tube by itself and the hole did not align.
jimh406
Western MT
Posted: 10/27/22 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I missed the first picture.
Bedlam
PNW
Posted: 10/27/22 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
So is the receiver drilled incorrectly or the extension tube drilled crooked? I looked at the picture and cannot figure which is faulty. As others posted, each tube can be inserted into the receiver individually and pinned, then the clamps are applied. Once fully assembled and tightened, there is no reason to touch the clamps and the double truss can be installed or removed as a complete assembly.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
ticki2
NH
Posted: 10/28/22 04:27am Link  |  Quote  |  Print  |  Notify Moderator
Or is it the reinforcement ring . Did you try the pin from the other side as fa as it will go and does it look straight . Either way it is made wrong .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Geo*Boy
Unknown
Posted: 10/28/22 08:10am Link  |  Quote  |  Print  |  Notify Moderator
BigSwick wrote:
Reality Check wrote:
BigSwick wrote:
Curious to how much weight the Supertruss adds with the extension over stock hitch? (and therefore decreases your "legal" camper carrying capacity?)
it must be significant.
It's beefy, but not that heavy. If someone is that close on capacity, they have other issues. And towing anything probably shouldn't be on the menu.
After some net searching, I estimate that for my application, the hitch itself would add about 30 pounds over the stock hitch. A 36" extension adds about 70 pounds. If towing a 3500 pound trailer, there should be about 350 pounds of tongue weight. All the above reduce the carrying capacity you can put in the bed (your camper). If you have a 4500 or 5500 series truck, it probably won't be a factor. If you have a 2500 or 3500 series truck, you should take notice..
Really, wow!!
Page of 5
