RV.Net Open Roads Forum: Fifth-Wheels: Replacement of Suburban water heater...
 > Replacement of Suburban water heater...
Retired 404
Woodward
Posted: 10/17/22 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing a Suburban water hater (SW12DE). Removing and replacing seemed pretty straight forward, however... Upon removing the old unit, there were four wires that had to be disconnected from the RV itself: 1-red/red 2-green/green 3-blue/blue 4-white/orange New unit does not have the orange wire...
No idea where or what the white wire going into the RV is for.
* This post was last edited 10/17/22 03:10pm by Retired 404 *   View edit history
joelc
Cedar Point, NC
Posted: 10/17/22 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced mine a couple of years ago and if I remember some wire colors did not match, but I took photos before I disconnected anything. I doubt I still have the photos, but if I do I will edit this blog and try to send you the pics if you need them. I have a 10 gal elect/propane. Is yours the same?
Retired 404
Woodward
Posted: 10/17/22 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
I think I may have edited my post to include a url of the photo's I took.
Thank you for your reply sir!...
MFL
Midwest
Posted: 10/17/22 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
^ I don't see a pic. Just google rv.net photoposting for an easy to follow link.
BB_TX
McKinney, Texas
Posted: 10/17/22 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Your pictures
Here is the Suburban manual. Maybe page 11 figures 10 and 11 will help understand the wiring.
Suburban manual
Retired 404
Woodward
Posted: 10/17/22 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip...
Here is the photo link:
Retired 404
Woodward
Posted: 10/17/22 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the schematics/owners manual...
dougrainer
Carrolton, Texas
Posted: 10/18/22 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Suburban has 2 models of 120 dsi water heaters. Your OLD unit has the 12 volt activated 120 relay that that white wire was connected to the orange. The white should have 12 volts when you turn the inside 120 water heater switch ON. Your new unit, does NOT have the relay and was the older style that had direct 120 to the water heater. You had to have either a 120 rated inside wall switch to turn it ON or use the outside On/Off switch below the gas valve. Look at this link and determine which model you have. DE or DEL. Doug
https://suburbanrv.com/files/product_doc........trols/Tank%20Water%20Heater%20101121.pdf
Retired 404
Woodward
Posted: 10/19/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Doug, thank you for the clarification.
My new unit is the Suburban Sw12de (5247a).
I guess my next question is what are my options?
-Return this unit (thought was a good deal @ $559 and free shipping)
-replace the control panel
-use this unit and control it from outside
dougrainer
Carrolton, Texas
Posted: 10/19/22 09:48am Link  |  Quote  |  Print  |  Notify Moderator
If you can return it and get the correct model, that is your best option. BUT, If you have to pay return shipping and the correct cost a lot more, then use this model and control from the outside switch. Doug
