marpel
notapplicable
Small trailer with 6 gallon hot water tank.
Am considering, prior to next season, replacing it with a 10 gallon.
Is the difference in size that significant, and has anyone done this sort of thing, who may provide advice or things to be aware of?
Marv
midnightsadie
ohio
#1 you got the room for a 10 gal?
BB_TX
McKinney, Texas
According to the Suburban manual the 10 gal is about 3 1/2” wider and taller and about an inch deeper then the 6 gallon.
BobsYourUncle
Calgary Alberta Canada
I did a repair on a friends 5'ver a number of years back. He had a 10 gallon tank that died in a CG we were both staying in. He bought a new unit at the local RV place and I swapped it out for him.
The tank itself was ok, so I kept it, thinking I would repair it an swap mine out, going from 6 to 10. I wish it was that easy.
As mentioned, physical size difference.
For obvious reasons, the 10 is bigger. It requires a bigger opening to fit in. This requires surgery on the wall of the RV to provide solid framing all around to screw the unit in.
On mine, I didn't have enough extra width and height to make it an easy conversion. I would have had to carve up a partition, do cosmetic repairs and more, so I scrapoed the idea.
However, if you have enough extra width and height inside, and you're willing to enlarge the opening of the outside wall, yes it is doable.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Dick_B
Palos Heights, IL USA
Always curious; why go to larger water heater? More people...longer showers...
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
marpel wrote: Small trailer with 6 gallon hot water tank.
Marv
This does not seem like the type of query to "phone a friend" over.
Noone here would have the slightest clue whether a larger water heater would fit in you RV or exactly how much of a project it is to switch out.
But, I bet you could find the size of one on the internet in less time than it takes to write this post, and then go break out the tape measure.
marpel
notapplicable
Thanks everyone for the responses.
Grit dog - Din't ask if anyone thought a larger water heater would fit in my particular trailer. Just wondering if anyone had done this sort of thing before and if they could provide some "guidance/be aware of" input. If someone has done this sort of thing before (and I wouldn't know without asking), they sure would know how much of a project it is to switch out.
Marv
