MFL
Midwest
Grit dog wrote: I'd heat my whole shop with a big IR gas fired heater....if it was insulated and finished inside and I had one of those heaters. Lol
Not really understanding the question...Yes many people heat their shops for different reasons, including keeping things from freezing.
My garage, with shop, is finished and fully insulated, including windows/doors. I have a Reznor overhead hanging 75K btu NG furnace. I keep stat set above freezing, all Winter.
Nothing freezes, and if I'm working in there, set temp to 60, which takes about 10 minutes to reach. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Jerry
C Schomer
Pueblo West, Co.
10 W per square foot is what I used for an average house and that might also keep the temperature above freezing if the garage is not insulated but it needs to be airtight also. Insulation and eliminating air infiltration are the best things you can do to keep heating and cooling costs down.
My garages are well insulated but I had a wood finishing job to do a couple of years ago, in the winter, so I used shipping blankets and hung a curtain around my work area and used an electric heater inside that area and it did a nice job. Try to reduce the area that you need to heat. I’d even consider building some insulated portable partitions if you’re going to do that every winter. Craig
MFL wrote: Grit dog wrote: I'd heat my whole shop with a big IR gas fired heater....if it was insulated and finished inside and I had one of those heaters. Lol
Jerry
Yeah buddy!
riltri
Husk & Steinhatchee
To clarify, I'm referring to the garage in our 5th wheel.
I purchased a small 700W radiator heater. Ran a test last night....temp dropped to 27. I just checked and the temp is well above freezing. The drinks are cold but not close to freezing. I forgot to put insulation where the water hose comes into the garage which is the only hole I can find that needs plugging. I will continue to drain the water lines, hot water heater, all tanks and add pink to drains. But this will take care of our drinks and other liquids, which is what I want to do.
Blue Ridge Mtns - NC
dedmiston
Coast to Coast
Administrator
riltri wrote: To clarify, I'm referring to the garage in our 5th wheel.
The garage is always the coldest spot in our toy hauler, even when we're running the furnace and/or the electric fireplace.
Have you thought about spreading a welder's blanket over your cases of drinks to help insulate them?
Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
AJR
Close to Madison Wisconsin
OP said....
2014 Leprechaun 290QB
Chevy 4500 6.0
2015 GMC Terrain AWD
dedmiston
Coast to Coast
Administrator
AJR wrote: OP said....
Thanks for clarifying his clarification.
dedmiston wrote: AJR wrote: OP said....
Thanks for clarifying the clarification of his clarification!
Retired JSO
North Georgia Mountains
If your basement has a wet bay hole for hoses, television cords, plug it up and and just use a 40 watt lightbulb in there. We were in a NC campground during the winter of 20 while our home was under construction. Had many mornings 12-15 degrees not getting above freezing all day.
Pbutler97
Midwest
Grit dog wrote: dedmiston wrote: AJR wrote: OP said....
Thanks for clarifying the clarification of his clarification! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Thanks, it could not be more clear........could it? LOL
