unbob wrote: Tom/Barb wrote: Why does it require a repair? Sustained several "puncture wounds" due to flying debris from a nearby tornado. Two windows broken also. And blew away my solar panels on the roof. Otherwise no apparent structural damage. But interestingly, insurance company totaled it and I did a buy-back.
I haven’t been around BF campers but believe the fiberglass w gel coat construction similar to boat construction and repairs.
Gel is totally different to work with than autobody repair. And in many ways easier.
For the holes, you will want to fill them back up with likely autobody filler bondo.
Then prep the repair by grinding back down about 1/8” max with sharp edges (not feathered)
Fill the areas back up flush of slightly above flush with thick gel coat (like with a putty knife or bondo spreader). Cure the gel cost and sand back to flush, cut and polish. (Read up on how to cure the gel)
The repair will be seamless.
For color match, you can get a small universal gel repair kit that comes with white gel and mixing colors to tint it. That part may be trial and error but you can experiment on a piece of cardboard first until you get a close match if needed.
FWIW, I’d do gel repairs all day long vs paint repairs.
Tom/Barb
Oak Harbor, Wa
Get the proper color Jel-coat from Big Foot then cover the hole with scotch tape on the out side of the repair.
then mix a small amount of jel-coat and apply with a small Brush until the hole is covered on the inside of the repair, allow to jell. then make the repair on the outside of the repair..
Then sand smooth buff, polish as required.
The way they are made the Gel-coat goes in the mould first, in a cavity mould, then the fiberglass is laid up inside of mould.
you make the repair the same way.
terrybk
Central Coast California
Grant at Bigfoot would likely tell you the color code (even going that far back.) He tells me pretty much any obscure detail I've asked. Lol.
But as stated, fading will probably make new paint of the right color code stand out so definitely go to an auto paint place and have them measure the color. That's about as close as you can get. But if you know the original color code you can compare the values and see just how much your color might have shifted over time.
2005 Chevrolet 3500 SRW 4X4 LB/CC D/A
2006 Bigfoot 25C9.4LB
CEK0515 and a dog
Tom/Barb wrote: unbob wrote: Tom/Barb wrote: Why does it require a repair? Sustained several "puncture wounds" due to flying debris from a nearby tornado. Two windows broken also. And blew away my solar panels on the roof. Otherwise no apparent structural damage. But interestingly, insurance company totaled it and I did a buy-back.
Negative ghost rider. I mean, yes, most all ‘glass structures like boat hulls and campers are originally constructed in that order, for efficiency and consistent finish but it would be wholly unnecessary to tear apart the interior of a camper or boat to reach the inside, unless the repair area was large enough or did enough structural damage to warrant it.
On that note, OP has not done a good job of describing the damage other than “puncture wounds” which I presumed to be small. Hence the bondo first recommended. If larger, use kitty hair for filler. If larger yet, may require some access from the inside, but NOT for the gel application. That gets sprayed, brushed or smeared on from the outside. 100%.
terrybk wrote: Grant at Bigfoot would likely tell you the color code (even going that far back.) He tells me pretty much any obscure detail I've asked. Lol.
Who custom color matches gel coat? Auto body supply stores don’t in my experience. Obviously it possible but also not probable or practical in my experience doing a few random fiberglass repairs over the years.
