RV.Net Open Roads Forum: Beginning RVing: Oven will not ignite
 > Oven will not ignite
JR51
NY
Posted: 10/20/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Greetings campers,
I'm having a problem with my propane Magic Chef oven. The pilot lights fine but when I turn oven temp up it only makes the pilot flame a bit higher. Cleaned with small wire brush but no better. Just used oven 3 days before problem and worked fine. Manual does not help regarding this problem
Thanks in advance for any and all suggestions
nickthehunter
Midwest
Posted: 10/20/22 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Try cleaning the flame proofer. It’s the small metal rod that sticks out into the pilot light flame.
way2roll
Wilmington NC
Posted: 10/20/22 10:02am Link  |  Quote  |  Print  |  Notify Moderator
The thermocouple? That only uses milliamps to keep the solenoid open to allow gas flow. If the pilot stays lit, the thermocouple would not be the problem.
2023 FR Sunseeker 2400B MBS
ReneeG
Meridian, Idaho
Posted: 10/20/22 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Following in case this happens to us.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
toedtoes
California
Posted: 10/20/22 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
There are a few things it could be. First, it could be clogged up. To fix, take apart the burner assembly and clean it. Second, check to make sure the gas line behind the stove isn't kinked. Third, there is a small screw next to (might be covered by) the oven dial. That adjusts the pilot light. To the right of the dial should be a second screw - that adjusts the broiler burner.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
JR51
NY
Posted: 10/20/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Took what I could apart. Cleaned and inspected. Reassembled with same results. Pilot lights, turn up oven and pilot light puts out a 3 inch flame with no ignition. Solenoid? Any guesses because I'm getting no help from Magic Chef and no schematic in manual.
toedtoes
California
Posted: 10/20/22 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check the gas line behind the oven to make sure it's not kinked?
And did you adjust the screws next to the oven dial?
JR51
NY
Posted: 10/20/22 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for input. Did all of above. No change. Theres only one screw to the right of oven knob on my unit that controls pilot only.
toedtoes
California
Posted: 10/20/22 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Your fuel line may be blocked up. Is your lighting and the burner flames adjusting normally?
It could be a faulty thermocouple (if you have one - not all magic chef ovens do).
Posted: 10/20/22 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
You said it makes the pilot a bit bigger.. not sure it should do that. (not sure it should not)
Two suspects are the gas jet.. not sure where that is but look for the air admittance windows (usually two rectangles where the large burner pipe connects to something OTHER than the burner. The jet is in the smaller part A bone drill is suggested for cleaning (If you can unscrew it do so) Bone drills at welding supply.
And the control valve (that's an OUCH part).
