eHoefler
ozark mountains
When you turn the oven on and to a temperature, the pilot flame increases, then it will warm up the thermocouple, when the thermocouple comes up to temp, it will open the main gas valve to the burner. The time it will take depends on temperature the thermocouple starts at and altitude you are at. The thermocouple is a non electric device that is filled with freon, when heated it will build pressure and press on a button in the main gas valve.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
smthbros
WI
eHoefler wrote: When you turn the oven on and to a temperature, the pilot flame increases, then it will warm up the thermocouple, when the thermocouple comes up to temp, it will open the main gas valve to the burner. The time it will take depends on temperature the thermocouple starts at and altitude you are at. The thermocouple is a non electric device that is filled with freon, when heated it will build pressure and press on a button in the main gas valve.
A thermocouple is an electrical device. What you have described is a vapor bulb.
smthbros wrote: eHoefler wrote: When you turn the oven on and to a temperature, the pilot flame increases, then it will warm up the thermocouple, when the thermocouple comes up to temp, it will open the main gas valve to the burner. The time it will take depends on temperature the thermocouple starts at and altitude you are at. The thermocouple is a non electric device that is filled with freon, when heated it will build pressure and press on a button in the main gas valve.
You are correct Smthbros.. I used to think it was a vapor tube. It's not. it's a Thermocouple Generates a bit of current/voltage (about .480 volts and however much current the solenoid latching coil sucks at that voltage don't ask I've never measured).
The valve in the control valve is a magnetic latching normally closed valve. You push the button and the valve opens (or whatever you need to do to light) Light up and hold the button till the thermocouple is up to temp, voltage and current. then the current flowing "Latches" the valve open.. The magnet is not strong enough to open the valve as that takes many many times more 'Strength" than to hold it once manually opened.
JR51
NY
Trying to find where to get parts. Stove pre 1996 magic Chef Cooktop and range. Then try to figure out what the suspect part is.
Thanks for help and suggestions
Mr. C
SW Virginia, USA
30yr old stove? Maybe it's time to replace it...
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
StirCrazy
Kamloops, BC, Canada
Mr. C wrote: 30yr old stove? Maybe it's time to replace it...
the one in my camper is 31 years old and works like new. age has nothing to do with it in simple sstems as long as there mintained
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
