kaileybutler052
New York
Dear, please tell me how to understand from the description, what heating system is in dachlüftung camper: liquid or air? Here they write in the description: "central heat", how should this be understood? As I understand it, if it says "Truma", then it is air?
edited 11/14/22 09:01am by kaileybutler052 *
Second Chance
Wherever...
Truma makes tankless water heaters. The main heating systems in RVs are LP/Propane furnaces. The heat source is the LP and the fan and thermostat operate on 12VDC from the battery.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Reisender
NA
kaileybutler052 wrote: Dear, please tell me how to understand from the description, what heating system is in the caravan: liquid or air? Here they write in the description: "central heat", how should this be understood? As I understand it, if it says "Truma", then it is air?
It sounds like a Truma Alde system. That is a hydronic heat and hot water system. A propane burner and/or electric element heats glycol which is then circulated through a series of heat registers in the trailer. Dry quiet, super efficient. It’s a common system on higher end trailers. They have excellent reputations.
Hope that helps.
edited 10/22/22 07:48am by Reisender *
