RV.Net Open Roads Forum: Travel Trailers: New to traveling
 > New to traveling
Three50freak
Lillington nc
Posted: 10/25/22 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Looking to take a trip across the US for about a month with my family of 5 no pets. I need to buy a truck and camper. I'm going to be staying away from diesel for a few reasons and would like to stay around 30 or 40k total before maintenence and upgrades. I'm leaning chevy 1500 gas. Which means I should look towards a 5 to 6k lb trailer. Any suggestions on truck and camper would be great. It will need to pull the rockies fyi. I plan to boondocks a bit and stay on campgrounds for a few days along the trip, day every 2 or 3 days ish. Ty again
NamMedevac 70
Reno
Posted: 10/26/22 04:34am Link  |  Quote  |  Print  |  Notify Moderator
I have pulled a 5000lb 28 foot TT for many years with 3 different dodge rams. 2 were V8 1500s and a V10 2500 Ram. On the flatlands of Texas both my 98 and 01 Rams pulled the TT fully loaded both truck and ram without any problems at all and I used a Equalizer WDH.
I used my V10 2500 fully loaded to pull same trailer fully loaded thru the rockies and thru the west coast mountains of Oregon, California and Nevada.
My present 2014 Ram V8 hemi 1500 would also pull the same trailer in the west without any problems. You will need a bunkhouse mode TT for your size family or a heavier toy hauler TT that may be too much for a 1500 in the mountains.
JRscooby
Indepmo
Posted: 10/26/22 05:54am Link  |  Quote  |  Print  |  Notify Moderator
I will not tell you what you need, but you must understand even if you feed the biggest gas engine you will hear a lot of the mountains will slow you down
Point is if your load is to heavy you might not want to run WFO all the way up the hill to avoid overheating. As soon as the temps starts up, back out of it, let speed drop. Will others pass you? So what! A mile long climb, at 60 MPH, takes you a minute. Same hill, at 20 MPH, takes 3 minutes. Traveling the country you will find very few places that the biggest engine will run 60, and the smallest will pull down below 40. If the manufactures don't use bigger brakes with bigger engine the bigger engine not worth that much in mountains.
Walaby
Georgia
Posted: 10/26/22 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Smaller trailer might be tough for family of five. Although kids might enjoy sleeping in a tent in the great outdoors. That will certainly help.
In today's economy, may be pretty tough to stay within 30-40K for truck and trailer. I don't want to say impossible, because someone will have an example of how they got truck and trailer for spit and a promise.
I would buy the best/newest/most reliable truck I could get. Last thing you want is to break down with family of 5 on side of the road. Make sure whatever you buy has a tow/haul mode and preferably selectable gear setting for the trans so you can have some non-brake control on the downhill side.
I would think a half ton with a 5-6K trailer could work out okay, but as JRScooby says, don't push it up hill, and take it easy coming down.
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
JIMNLIN
Oklahoma
Posted: 10/26/22 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum..
If your going with a 1500 GM product pulling a trailer be sure and get the NHT package (tow package). It comes with the higher rated gvwr and rawr numbers.
A 2014 and up 1500 gm you also can choose between the 5.3 engine at 355 hp/383 torque or the 6.2 engine at 420 hp/460 torque. Both can come with the NHT package. The 6.2 engine can tow GMs 1500 trucks tow ratings with ease.
Older engine were down on power levels.
And also be aware of some GMs engines AFM/valve train (cylinder deactivation issues) with the 5.3 and 6.2 engines prior to 2021-22 ?? models. Google has lots on this subject.
My wifes has a '16 1500 chevy 4wd crew cab short bed 5.3 engine 6 speed tranny 3.42 gears (not the NHT package). IMO a 6k-6.5k wet weight trailer would be the max I would want to pull around the country with the 5.3 engine.
The 6.2 engine can handle a 7k-7.5k lb trailer.
Good luck on the hunt.
Lantley
Ellicott City, Maryland
Posted: 10/26/22 06:41am Link  |  Quote  |  Print  |  Notify Moderator
If you are buying a truck to specifically tow cross country pulling a family size RV trailer get the diesel. gasser is fine if you are a weekend warrior but if you are crosscountry towing you will want the power, fuel range and fueling cnvenience of a diesel.
A lower priced truck is no bargain if it is the wrong truck.
Keep in mind most any diesel will do what you want,however you will need to be selective and choose the correct/right truck if you go gas.
Even then the gasser will not equate to a diesel.
The diesel difference is for real when it come to cross country RV towing.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Three50freak
Lillington nc
Posted: 10/26/22 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I'd go diesel but all the ones I'm finding in my 30k price range for the truck have 200k miles. Now I know a dmax is ok at that but not wanting to spend 30k to turn around and put a long block or transmission in too soon. That's 4500 a pop if I do the work.
JRscooby
Indepmo
Posted: 10/26/22 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Is a sedan without trunk lid (pickup) the only thing that can tow a trailer?
I think I would look into a full-size van. Likely more seating space. Could be made into kid's bedroom. Can have same GVWR/GCVWR as pickup. Plus vans often have the wheels set out to corners/less rear overhang. This design would make for more stable towing.
tomman58
Southeast Michigan
Posted: 10/26/22 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I will always remember doing an Apache popup with 2 kids. I admire the fortitude of those with more than 2. I think I would have to have a tent for the older ones. Good luck with your choice. One thing we did as we approached our first trailer was to go to parks and talk to those doing what we we looking to do.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
Southern California :(
Posted: 10/26/22 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Welcome! Thirty to forty thousand isn’t enough for dependable truck and trailer IMO. I drive a half ton truck with a 5500 pound wet and loaded trailer and two people. With five I’d think 3/4 ton truck to stay within the truck’s payload.
 > New to traveling
