RV.Net Open Roads Forum: Finally got the truck, next will the fifth wheel fit ?.
 > Finally got the truck, next will the fifth wheel fit ?.
Page of 5
tourusa
Ft Lauderdale
Posted: 10/27/22 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all, finally got the f350 dually with 8ft bed, previous owner was doing hot shoting and I have an aux tank and tool box in the bed .
The issue I’m concerned about is which fifth wheel hitch would you suggest , and with all left in place do I have enough clearance for any turns with a 30ft fifth wheel, suggestions on if I need a sliding hitch or suggestions appreciated
My question is do I need to remove all or just the tool box to ensure I have 5th wheel clearance
From the top pin to the tool box I have
3ft from forward pins to start of tank
26 inch height tool box installed with but can be separated from the tank
31 to top of tank caps
Pictures below
* This post was edited 10/27/22 06:15pm by tourusa *
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
MFL
Midwest
Posted: 10/27/22 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
"My question is do I need to remove all or just the tool box to ensure I have 4 wheel clearance"
^^^Pictures are a good idea, but statement above, a bit unclear?
Maybe you could post a bit more, better describing what problem you are trying to solve?
What type hitch do you plan to use?
Jerry
fj12ryder
Platte City, MO
Posted: 10/27/22 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
"4 wheel clearance"?
Howard and Peggy
"Don't Panic"
Retired JSO
North Georgia Mountains
Posted: 10/27/22 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have an above bed tool box and can completely jack knife our Cardinal.
Durb
NW
Posted: 10/27/22 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
You should be good without removing either assuming that your fifth wheel has sufficient bedrail clearance. Your filler caps are too far forward to be a problem. You will have to keep watch if backing sharp up an incline.
tourusa
Ft Lauderdale
Posted: 10/27/22 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hi thanks all for the quick response I’ve updated the questions
The issue I’m concerned about is clearance with the tool box and aux tank, also which fifth wheel hitch would you suggest , and with all left in place which I’m not convinced I need an AUX tank ? Open to comments, do I have enough clearance for any turns with a 30ft fifth wheel, suggestions on if I need a sliding hitch or suggestions appreciated
tourusa
Ft Lauderdale
Posted: 10/27/22 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
How do I ensure I get the correct hitch for bed rail clearance ? Any suggestion on hardware curt etc appreciated
MFL
Midwest
Posted: 10/27/22 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of B&W hitch fans on this forum, including me. While there are other hitches that will fit your OEM puck system, IMO, the B&W Companion 3300 is the best choice for ease of use, and great fit to the pucks. It can easily be adjusted up/down, and ahead/back.
Since you have a DRW, capable of towing a FW of more than 20K, you may want to consider the 3305, same as above, but rated to 25K.
Jerry
tourusa
Ft Lauderdale
Posted: 10/27/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks jerry for you assessment and recommendation, and when not in use easy to uninstall, and you mention adjustments. Do I need a sliding hitch with the tool
tourusa
Ft Lauderdale
Posted: 10/27/22 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Link to hitch
Looking for the 3305 now
* This post was edited 10/28/22 11:25am by an administrator/moderator *
Page of 5
