RV.Net Open Roads Forum: Class A Motorhomes: Exhaust brake quit working
 > Exhaust brake quit working
larry cad
ohio
Posted: 10/31/22 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
captron33 wrote:
Spartan confirmed i have a 2 stage exhaust brake., based on my vin number.
Did they offer any suggestions on the problem?
Our Travel Blog
captron33
usa
Posted: 11/03/22 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
No, probably not electric.
larry cad
ohio
Posted: 11/04/22 04:54am Link  |  Quote  |  Print  |  Notify Moderator
Then I would look into the butterfly valve mechanical operation. The valve is easy to remove and then it is easy to verify if the valve is working.
oldave
Tx
Posted: 11/04/22 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
2-stage exhaust brake? Are you sure? Not an engine brake? I believe a 2-stage is an engine brake.
An engine brake is much more effective.
Ray,IN
IN, USA
Posted: 11/04/22 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Then your engine has a 2-stage engine compression(Jake) brake, not an exhaust brake. The Jacobs compression brake opens the exhaust valves just before the piston reaches TDC on compression stroke.
reference: https://official.bankspower.com/tech_article/how-an-exhaust-brake-works/
and
https://www.jacobsvehiclesystems.com/technologies/compression-release-engine-brake
2000 Winnebago Ultimate Freedom pushed by a 2013 Chevy Silverado K1500 And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
wolfe10
Posted: 11/05/22 10:57am Link  |  Quote  |  Print  |  Notify Moderator
No such thing.
If two stage, it is an ENGINE COMPRESSION BRAKE.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
wolfe10
Posted: 11/05/22 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Please explain what this means.
Thanks.
captron33
usa
Posted: 11/06/22 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Its labeled exhaust brake on the switch. Hi and low. Obviously I’m not a mechanic, i will take to one to get it looked at and fixed. Its in storage for 6 months or so for now. Spartan told me the only electrical component is a diode. So no cb,s to check out.
wolfe10
Posted: 11/06/22 09:54am Link  |  Quote  |  Print  |  Notify Moderator
With a two stage engine compression brake, you WILL have an electric signal that both downshifts the Allison (left or only shift pad window will change from 6 to some lower gear-- often 2nd or 4th) AND will signal the engine ECU to apply either 3 (low) or 6 (high) compression braking.
