RV.Net Open Roads Forum: Technology Corner: Connect Bluetooth Headphones to TV
 > Connect Bluetooth Headphones to TV
Kountryguy
Emery,SD
Posted: 10/28/22 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a way to get TV audio to play through bluetooth headphones? Would a bluetooth dongle plugged into the usb connection work?
jorbill2or
Full time
Posted: 10/28/22 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Yes search for bluetooth audio transmitter for tv. You’ll find several. All with different input methods rca ( headphone Jack ) optical out etc and some for one connection out and some that can handle two separate audio devices ( two headphones) The usb out I would think depends on the tv’s capabilities
Bill
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/28/22 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use a small unit connected to the Optical output and converts it to Blue Tooth to work with my Hearing Aides. Seems would be very similar to work with Blue Tooth Head Phones.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Ed_Gee
Central Oregon coast
Posted: 10/28/22 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Question for Michelle -- when connected to the optical audio out , does that kill your local TV speaker sound for others in the room?
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Dutch_12078
Winters south, summers north
Posted: 10/28/22 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have a similar setup to Michelle's, and no the optical connection does not kill the local speakers. I can control my hearing aid volume independently of the TV volume including muting the TV without affecting my hearing aids.
Dutch
2001 GBM Landau 34' Class A
Michelle.S
Posted: 10/29/22 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Dutch, but I don't actually connect to the TV as I use the optical output of our DirecTV Receiver because the optical output of the TV is connected to the Sound Bar, which I just turn off.
