Pbutler97
Midwest
Join the Forest River owners forum where you may get your answer and probably
find someone with the same trailer. You won't get it here. There are a hundred + threads about solar here, and all are a mashed up pile of back and forth arguing about things where the participants are mostly wrong to begin with, basically BS.
Housted
Los Angeles, CA
Solar ratings are based on being at the equator at high noon on June 30 on a clear day with the panels facing at the sun.
In other words you will probably not see the full wattage anywhere in North America.
Its not magic or mysterious just remember more solar is better than less.
The same goes for battery reserve.
I have 1000 watts of solar and a 400 Amp HR lithium battery and it serves us very well. I do not try to run the A/C off the inverter.
YMMV
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
Southern California :(
Housted…RVer with the big roof covered with solar! lol
time2roll
swimmer_spe wrote: OP here.
Many of you are posting without knowing what my trailer is equipped with. The questions about the battery, panel and other electrical questions do not help. I am not looking for someone to do math. I can do that.I am looking for someone who has one and knows what it can and cannot do. Unplug and check what works.
Fridge should work best on propane. (Probably has 12v controls and ignition)
Lights will work. Maybe not the ceiling fan
Water pump works
Water heater should work on propane. (probably has 12v controls and ignition)
Electric front jack should work. Possibly the leveling jacks.
Furnace should work burning propane. Has 12v fan and electronic ignition.
Cooktop and oven should work on propane.
No microwave
No air conditioning
No electric water heat
No electric outlets
What did I mis?
edited 10/29/22 02:46pm by time2roll *
675w Solar pictures back up
bikendan
Goodyear, Arizona
Pbutler97 wrote: Join the Forest River owners forum where you may get your answer and probably
x2! RV.net is a general RV forum. If you want model-specific information and feedback, a brand-specific forum is a better resource, than RV.net.
Forest River Forums have sub-forums for every FR brand. The Toyhauler section has a Cherokee sub-forum.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
pianotuna
Regina, SK, Canada
Swimmer,
Rule of thumb, 1 battery 1 night. That assumes no recharging.
So tell us the amp-hours of the battery and the wattage of the existing solar panel.
If you don't want to do math, then connect the rv to a kill-a-watt meter and measure for 72 hours. Do not exceed 1800 watts or the meter will turn into a poor door stop.
edited 10/29/22 08:05pm by pianotuna *
Regards, Don
Boon Docker
Why don't you give us your expertise on the subject then.
ktmrfs
Portland, Oregon
Housted wrote: Solar ratings are based on being at the equator at high noon on June 30 on a clear day with the panels facing at the sun.
YMMV
Housted
and it assumes using an MPPT controller AND at a pretty low temperature.
Hint. to best aim the panel take a empty TP tube, place it perpendicular on the panel and adjust for zero shadow.
I have two 200W portable panels going to a 30A MPPT controller. In theory I should be able to get 30A out of this. In practice (1) seldom is there an absolutely clear sky, any haze, smoke, etc. even if you can't see it affects output, (2) seldom is the temperature down around 60F in the middle of the day, let alone panel temps 70F or below. I can usually count on getting 20-22 A at the peak of the day properly aimed on a bright day.
If I add my third portable 200W panel then I can max out at 30A.
I also have three 160W panels mounted flat on the roof going to another 30A MPPT controller. Again theory say 30A no problem. but (1) a flat panel at northern latitude in the spring or fall drops max output by about 50%. I can usually get 15A and when I parallel the third portable panel with the roof properly aimed up in the mid 20's.
the two MPPT controller can have the outputs in parallel, roof controller is the master, portable is the slave.
so between the combo of three 160W flat panels and three 200W portable aimed panels I can see 45A occasionally 50A or so for peak charge current, when in theory I could get around 75A. Now with proper aiming the roof panel output would go up, but with roof mounts that's pretty much impossible. And even though I can raise the roof panels, seems like seldom can I raise the roof panels to aim anywhere near south. usually end up parked so raising them the either face east or west.
2011 Keystone Outback 295RE
swimmer_spe
Sudbury, Ontario, Canada
I just posted this there. Thank you for the advice.
swimmer_spe
time2roll wrote: swimmer_spe wrote: OP here.
Water pump works
No microwave
No air conditioning
No electric outlets
What did I mis?
Fridge is only 12v.
The stabilizing jacks are crank.
The lights are all LED.
