RV.Net Open Roads Forum: Class C Motorhomes: Testing water system. Almost no leaks
 > Testing water system. Almost no leaks
SCADAMAN29325
Clinton, SC
Posted: 10/29/22 03:18am Link  |  Quote  |  Print  |  Notify Moderator
Just filled up the water tank for the first time. No leaks from the tank!
Hooked up the 120vac and turned on the water pump. Water comes out all the places it should!
Shower stream is WEAK! On the list.
Wet bay is WET! I can see one dribble out of a valve stem, but I think there is another. I may try to tighten the valve collar. Or maybe even repack it. It's only 28yo, should last another 28 when I turn 90.
Also tested the drain valves for the tank and pump, it dribbles out the pipe through the bottom of RV just like I was expecting.
Next I will fill the gray tank. Then the black.
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19.
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
Southern California :(
Posted: 10/29/22 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Twenty-eight years old and only minor issues? That’s great. Be gentle on tightening. Not like me!
bgum
South Louisiana
Posted: 10/29/22 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of things dribble when they get old.
