RV.Net Open Roads Forum: Tech Issues: Travel Trailer electrical, - Inverter placement/hookup
 > Travel Trailer electrical, - Inverter placement/hookup
Page of 5
ewarnerusa
Helena, Montana
Posted: 10/31/22 09:24am Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Could install a 30TT receptacle fed from the inverter, adjacent to the shore power cord, plug the cord into it. You must disconnect or turn off the converter...
No need to install a 30 Amp outlet, just plug your shore power cable with dogbone adaptor to standard AC plug directly into the inverter. Our inverter is installed in a location where I can conveniently do this and that is what we do. Converter switched off via AC panel - I have it on its own breaker. I also switch off air conditioner and water heater on the AC panel to avoid accidentally energizing them when running on the inverter. We 100% boondock and have been running it like this for 10+ years.
Aspen Trail 2710BH | 470 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
3 tons
NV.
Posted: 10/31/22 11:17am Link  |  Quote  |  Print  |  Notify Moderator
wolfe10 wrote:
How are you going to charge the batteries/
I would NOT recommend that.
You only want to enable some outlets/appliances to be able to run on the inverter. Certainly not the roof A/C.
Yes, the "details" on the wiring depend on the inverter you choose. Many have a "pass through" feature, so if it receives 120 VAC from shore power or generator, it does not invert, merely "passes the other source through.
Cleanest way is to either use a sub-panel downstream of the inverter with only those things you want to power from the inverter. Need to move not only the hots, but neutrals and grounds from those circuits.
As you get closer to choosing equipment, give us details on that as well as what battery bank you have and what you want to be able to run when on inverter power/dry camping.
BINGO! When running from the inverter the sub-panel sequesters certain items (like the air conditioner, water heater, onboard converter-charger, refer, as you see fit) from the inverter’s output - this method prevents the ugly, sure to occur event of an inadvertent battery drawdown…Based on your particular enquiry my recommendation would be a pass-thru type pure sine inverter or pass-thru inverter-charger combo (both having a built-in ATS) of at least 2000w (e.g. microwave capable)…JMO
3 tons
TomC71
Northern Ontario
Posted: 10/31/22 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Is there any reason I can't just take the wire coming off the breaker for the plugs and it's negative of course, and hook them to my inverter and skip what it seems a lot of people have done?
As I said, I am just looking to power the plugs in the trailer.
I have to look to see if I have the wiring diagram for it and see if the plugs are isolated from everything else or part of another circuit.
3 tons
NV.
Posted: 10/31/22 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
First off, no doubt, just about anything that folks can think up has already been tried (with varying degrees of success and failure…)…The method you suggest (without a ATS) would create a electrical hazard if you forgot the inverter was ON and started the genny or plugged in to shore power, nor would it allow you to run the microwave since it is on its own dedicated circuit…Rules are just a consequence of mistakes - Rather than rely upon memory, you should plan on having an approved means of isolating the inverter from shore and genny power.
3 tons
TomC71
Northern Ontario
Posted: 10/31/22 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
This was the sort of thing I was referring to when I mentioned people making assumptions.
We've lived in a travel trailer since last year, 100% off grid. We do not use a microwave, don't use the furnace, A/C unit and don't have any high power draws at all. We power our lights, radio and charge our phones, tablet, laptop and internet hub. Our 'new' trailer, is the same year, just a slightly different configuration of trailer. It doesn't even have a roof top AC/furnace unit in it.
That was why I said I was looking for a way to power the AC plugs (which is not the A/C plug...)
I want the AC plugs working so we can plug our phone/tablet/laptop in to them to charge them.
As for the multiple comments about 'forgetting it' when hooking it up to shore power, either with a generator or shore line, we have literally never, not even once, hooked either to our trailer. The very, very rare occurrence (twice last winter), when we used our generator, it was to charge the batteries up when we had a few too many cloudy days in a row.
Krusty
Calgary, Alberta,Canada
Posted: 10/31/22 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
I added another 15-amp breaker to my breaker panel. I connected a 12-gauge cable to the breaker and ran this to my 2000-watt inverter. The inverter back feeds the panel and it will power up everything I want it to. Not the "correct" way to do it but it works fine and does everything I need it to.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Cptnvideo
Arizona - most of the time
Posted: 10/31/22 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I hope you remember to turn off that breaker before connecting to shore power.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
3 tons
NV.
Posted: 10/31/22 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
Huh?? I don’t get your unwarranted admonishment??….Recall the old sage advice regarding ‘assumptions’, and you should consider that this goes in both directions!! - Given such a limited but evolving description, are others to merely assume your specific scenario, or level of competence - Really??… Either way, you’re very welcome (lol!), and I’m sticking with the previous advice for the larger audience as follows,
“Rather than rely upon memory, you should plan on having an approved means of isolating the inverter from shore and genny power.”
3 tons
TomC71
Northern Ontario
Posted: 10/31/22 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
You already DID make assumptions, as did others. Now when I clarify why those assumptions are totally wrong and pointless, you whine?
Have you ever tried asking questions instead of making assumptions?
"Hey Tom, what are you planning on powering through the plugs?", "Do you ever plan on being hooked to shore power?", "Could you tell us more about your set up?"
Or you could, as you did, assume you know everything you need to and offer suggestions based on those incorrect assumptions.
2112
Posted: 10/31/22 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
All I can say is WOW!
I would tell you how I installed my two inverters but I assume you already know.
How long is this string?
2013 KZ Durango 2857
Page of 5
