RV.Net Open Roads Forum: Tech Issues: Travel Trailer electrical, - Inverter placement/hookup
 > Travel Trailer electrical, - Inverter placement/hookup
Page of 5
time2roll
Posted: 11/01/22 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
TomC71 wrote:
Is there any reason I can't just take the wire coming off the breaker for the plugs and it's negative of course, and hook them to my inverter and skip what it seems a lot of people have done?
As I said, I am just looking to power the plugs in the trailer.
I have to look to see if I have the wiring diagram for it and see if the plugs are isolated from everything else or part of another circuit.
Yes that is what I suggested but with a small automatic transfer switch to make it user friendly for all that might need power.
675w Solar pictures back up
3 tons
NV.
Posted: 11/02/22 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Since you heretofore seem to frown on having a means of isolation, how is tying into the back of the panel any different than simply plugging the inverter’s output into a receptacle and back-feeding the remaining house outlets??
3 tons
StirCrazy
Kamloops, BC, Canada
Posted: 11/02/22 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
but if you are using a auto transfer switch wouldnt that just replace the main supply wires coming into the power center.. seams overly complicated to use that then wire it to a breaker.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
StirCrazy
Posted: 11/02/22 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
TomC71 wrote:
ewarnerusa wrote:
because it is simpler? The only additional thing powered would be the air conditioner. which as you said, you never run.
Simpler in the short term maybe. Not if something in the 37 year old converter/panel box goes on the fritz. This way I don't have to worry about it.
if you don't want to screw with it add a auto transfer switch and power the whole power center. if you don't want to use the AC then turn off the braker for that and just use the plugs. I havent said anything up to now but I cant stand half assed jobs. your going in there anyways just put in a auto trans fer switch, feed one side from the shore power feed the other from your inverter and done. if you decide to sell the rv later the new owner will thank you instead of powsting on here "I cant get my AC to work" panels are easy to change and not that expensive. at 37 years old you should replace it anyways if you are charging batteries with it, or just want filtered dc power for your electronics.
3 tons
NV.
Posted: 11/03/22 08:07am Link  |  Quote  |  Print  |  Notify Moderator
From just my perspective, seems more like what the OP is seeking is a tutorial and concurrence for an unsafe wiring scheme…
3 tons
3 tons
NV.
Posted: 11/03/22 08:55am Link  |  Quote  |  Print  |  Notify Moderator
TomC71, I notice that you’re a new member…Rather than displaying vulgar bitterness (recall, you never mentioned ‘money’, eh??) you might ‘appreciate’ that most of us here are interested conveying a safer, rational method and have invested personal time attempting to assist you…As per the principle of personal ‘free agency’ quite naturally you free to do what you wish - Good luck
3 tons
* This post was edited 11/04/22 07:40am by an administrator/moderator *
StirCrazy
Posted: 11/03/22 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Pretty sure the market for 40 year old rolling meth labs is pretty small... I wouldn't worry about the "next" consumer to get ahold of this beauty of a trailer..lol!
[emoticon]
TomC71
Northern Ontario
Posted: 11/04/22 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Actually I'll respond to the last poster even though I blocked them as well.
Yes, we were homeless until we bought this trailer and found someone kind enough to let us rent some land from them cheap. Our alternative was to live in a tent.
I don't know what is wrong with the people here on this forum, but I wouldn't even let most of you near my property let alone take advice from most of you. I ask questions to get other people's input. Whether I choose to follow them blindly, or whether I choose to do what is actually possible in our situation is up to me. That it offends some of you that people don't do what you say, says much more about you than it does me.
* This post was edited 11/04/22 07:54am by an administrator/moderator *
enblethen
Moses Lake, WA
Posted: 11/04/22 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Have you checked your private messages?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Y-Guy
Tri-Cities, WA
Posted: 11/04/22 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Heads up to all, including the OP, drop the insults and crude language. I'm not in the mood to play hall monitor today.
Page of 5
