RV.Net Open Roads Forum: Travel Trailers: Anything other than silicone..
 > Anything other than silicone..
rerod
Iowa
Posted: 10/29/22 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Ive learned on RV forums new silicone caulk will not adhere and seal to old and have avoided it like the plague since then, also considering how difficult it is to remove it.
Which type of caulk can you remove with a solvent and elbow grease, and also allow you to apply it over itself and be water tight?
Thanks
12 valve ram
bob213
Fresno, CA
Posted: 10/30/22 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Lexel
rerod
Iowa
Posted: 10/30/22 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
bob213 wrote:
Lexel
Thanks Bob..
When fungal growth finally stains white lexel, will a rag with solvent remove the stain? Which solvent?
Thanks
bob213
Fresno, CA
Posted: 10/30/22 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Bob..
Thanks
Not wet enough here to have that problem (yet) so I can't really say. I have reapplied over old with clear in the shower and a few other places without a problem. Cleans off pretty easy.
Turtle n Peeps
California
Posted: 10/31/22 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I don't know if it comes off with solvent but the pro's use Proflex RV. I just used Dicor on mine.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
4x4van
California
Posted: 11/03/22 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
rerod wrote:
Ive learned on RV forums new silicone caulk will not adhere and seal to old [emoticon]...
Yet a Youtube search says the opposite.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
Bobbo
Wherever I park
Posted: 11/04/22 10:35am Link  |  Quote  |  Print  |  Notify Moderator
And, you can believe everything you read on the internet. Including on this forum.
Bobbo and Lin
JIMNLIN
Oklahoma
Posted: 11/04/22 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the type of silicone being used.
What is the difference between acetoxy and neutral cure silicone?
***As acetoxy cure silicones release acetic acid whilst curing they can cause problems when used on certain substrates.
When used on natural stone they can cause discolouration, when used on certain metals they can cause corrosion and on bituminous surfaces they can cause "bleeding" of the bitumen.
So when applying sealant to sensitive surfaces we would always recommend using a neutral cure silicone over a acetoxy silicone as they will not react.
Generally acetoxy silicones are used for kitchens, bathrooms and other internal sealing applications as they are more cost effective and faster curing than their neutral curing counterparts.
Whereas **neutral cure silicones have better adhesion and weatherproofing properties** compared to acetoxy silicones making them the superior option for external applications.***
All I've ever used on my 1997 32' 5th wheel trailer is Dicor self leveling on the roof and their non sag Dicor on vertical surfaces.
Good sealants don't remove easily. Be sure and follow the sealant and the roof material instruction on removal.
rerod
Iowa
Posted: 11/04/22 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I should have said, once silicone has cured, new silicone will not stick or seal to it..
Are you saying neutral cure silicone once cured, will allow new neutral cure silicone to seal to it?
link to tile forum
rerod
Iowa
Posted: 11/04/22 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
Read the comment by Wyaj78
As someone who worked in the maritime industry for 20 years doing most everything you can imagine the answer is a resounding no. My first rule is to NEVER use silicone period. It’s a contaminant more than it is a sealant. I’ve never experienced it sticking to itself with any success... ever. I haven’t ever seen it not fail either.
When sealing anything the number one rule is to over prep the area you’re going to seal. This includes roughing up the surfaces and cleaning it of any oils before you continue. Removing existing silicone is extremely labor intensive. Sure, the bulk is removed easy enough but what’s penetrated into the surface area is fairly permanent creating a big problem because it won’t stick to its self let alone anything else.
Link
