David0725
I have a 2011 chevy Silverado can anyone recommend a wiring kit to install to tow 4 down?
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
Tom/Barb
Oak Harbor, Wa
I simply use the standard trailer wire harness from NAPA and just clamp the extra lights to the bumper/tailgate.
no electrical modification needed. It's a 4 pole harness.
things to consider, does the steering wheel lock ? if not no worries If it does, unlock it and disconnect the battery.
next question, is the truck an automatic or stick? some auto transmissions can't be spun for a long time with out lubrication.
edited 10/30/22 07:06pm by Tom/Barb *
David0725
The steering wheel does lock so I put a quick disconnect on the battery. It's a 4x4 truck so I put the transfer case in Neutral
Blaster Man
If an auto trans, it must be a 4 x 4 to tow four down.
2014 American Eagle
MountainAir05
New Mexico
Here is the manual, best to read your self.
https://my.gm.ca/chevrolet/en/content/dam/gmownercenter/gmna/GMCC/dynamic/2011/chevrolet/silverado/en/2011_Chevrolet_Silverado_Manual_en_CA.pdf
manual
ArchHoagland
Clovis, CA, USA
Davis0725 said:
"The steering wheel does lock so I put a quick disconnect on the battery."
How do you power the auxiliary brakes?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Tom/Barb wrote: I simply use the standard trailer wire harness from NAPA and just clamp the extra lights to the bumper/tailgate.
^ That's the easy button right there for lights. KISS principle.
Regarding transmissions, we can only wish GM still offered trucks with a stick shift in 2011...
Ponderosa
Western US
I recommend one of these Curt wiring harnesses. They have the diodes built in. For my application it was plug and play, but it looks like you would splice in the kit for your truck. Still much easier and fool proof than anything else on the market. This looks like the one you need, but verify make, model, etc.
https://www.curtmfg.com/part/58923
2015 Thor Windsport 32N
Tom/Barb
Oak Harbor, Wa
run a separate wire.
Gjac
Milford, CT
I used the Roadmaster wiring kit with inline diodes, it just installs using your own car lights and has worked well for the last 15 years until I gave the car away.
