fowlthing
Roger, AR
Bought it used two years ago. Got to looking under it today and the tires have been rubbing the underside through the coating and into the plywood. Three have gone pretty deep. Not sure when this happened etc.
Do I need to put on heavier springs? Or some kind of equalizer like the road armor shock absorber equalizer kit?
Have not had any heavy loads.
Three of the four has rubbed very hard. Might have been with previous owner.. tire wear has been normal.
Thoughts?
Smaller tire or new springs is the answer. One or the other caused the issue.
ktmrfs
Portland, Oregon
are the tires the Original equipment size as shown on the side of the trailer? Or did the PO put on a larger tire?
2011 Keystone Outback 295RE
fowlthing
Roger, AR
Not sure.. will check tire size. Bought at a dealer. They had put on tires.
fowlthing
Roger, AR
Where is the inverter/converter? can't see where it could be near the breaker panel.. unless I have to remove it completely to even see it... usually on trailers there will be a panel to unscrew.. don't see anything like this at all
ktmrfs
Portland, Oregon
likely no inverter, the converter (battery charger) is usually combined with the breaker panel. Common one is a WFCO. if the breaker panel has 120V breakers along with auto type fuses in the panel, it's a common combined breaker panel and built in converter. Converter is part of the assembly.
BarneyS
S.E. Lower Michigan
I suspect the previous owner put on larger tires. I would crawl under there and take a good look at the springs and also the note the tire size and compare with what is on the placard on the left front corner of the unit.
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
fowlthing
Roger, AR
Thanks... found the converter behind the fuse panel.. four screws to remove...and ordered another one. Will look to compare tires size...
Thanks again
Grant
Southern California :(
"...tires have been rubbing the underside through the coating and into the plywood..."
I suggest reinforcing the underside.
