RV.Net Open Roads Forum: Tech Issues: Two inverters for 50 amp service
 > Two inverters for 50 amp service
Page of 6
pianotuna
Regina, SK, Canada
Posted: 11/16/22 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
What? Why are you load controlling? Just feed the beast.
Hi time2roll,
He wants to limit shore power to xx amps so as not to blow shore power breakers. His existing inverter accepts two inputs--but doesn't allow limiting on line 2.
My personal choice would be identical to yours. Get one big inverter to handle all loads, and a 48 volt battery bank.
I suppose a case could be made for redundancy of having 2 inverters.
Regards, Don
Cptnvideo
Arizona - most of the time
Posted: 11/16/22 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
You're also missing the point, Don.
Bigger inverter implies not using shore power assist, which would therefore require more/bigger batteries.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
Cptnvideo
Posted: 11/16/22 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Load sharing isn't necessary for 50 amp shore. Doesn't exist for dry camping. It's for 15/20/30 shore power augmentation.
I might want to run 20 amps of loads while on 15 amp shore. With load sharing I would draw 50 ah from my batteries instead of 200 ah.
time2roll
Posted: 11/16/22 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Get a battery charger that will pull 80% of the available power to charge the battery.
The other issue is voltage drop and the power support inverters do not give voltage support. If the voltage sags in the park it could put you out of business.
Check the specs but most chargers will work down to 90 volts.
675w Solar pictures back up
Cptnvideo
Posted: 11/16/22 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
You still don't get it.
Check my signature, read my previous posts in this thread, read the specs and manual for the GoPower IC3000.
Then reply.
Thanks.
time2roll
Posted: 11/16/22 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Let us know how it works out.
Cptnvideo
Posted: 11/16/22 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, t2r.
We're currently plugged into 50 amp 2 pole at DW's sister's home. But when we get back to Phoenix in December, we will have the opportunity to augment 15 amp shore power.
pianotuna
Regina, SK, Canada
Posted: 11/16/22 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Cptn,
Nope. I'd never buy an inverter/charger that did not allow load support or shore power assist. It is FAR to convenient a feature to give up.
I actually down sized my battery bank once I had the Magnum unit.
On the other hand--I started with just a 2500 watt inverter and "limited" my power use by only plugging in the converter (about 800 watts). I'd plug the shore power cord into the inverter and do "double conversion".
I still have that ability as some gfci circuits do not play well with the Magnum 3000 hybrid inverter charger.
That "feature", the STUPID decision to use 120 volt cooling fans, and HUGE input surge are why I do NOT recommend the Magnum.
* This post was edited 11/16/22 09:12pm by pianotuna *
theoldwizard1
SE MI
Posted: 11/16/22 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
I read the original post and skipped everything else !
Will it work ? QUALIFIED YES !
Can You Power a 2........wo 120 Volt Generators?
I have not seen any RV that has 240V appliances and those clearly will NOT work !
Page of 6
