RV.Net Open Roads Forum: General RVing Issues: Carpet vs laminate or planking
 > Carpet vs laminate or planking
Bobbyg2013
Arizona
Posted: 11/01/22 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 40 foot RV with carpet and I want to replace that with either laminate or planking type material. The unit has 3 slide outs. Looking for advise as how to proceed and what I need to know about possible problems (i.e., scratching the floor when slide outs are moved in and out, etc. Thanks in advance.
PartyOf Five
Wheaton, IL
Posted: 11/01/22 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Vinyl plank works well and is ready to install.
PartyOf5 appreciating our Creator thru the created. 5 yrsL 50k, 49 states & 9 provinces.
May you find Peace in all you endeavor.
Southern California :(
Posted: 11/01/22 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Washable throw rugs can “carpet” any area you choose.
JimK-NY
NY
Posted: 11/01/22 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
I would go with thin vinyl flooring rather than heavy planting type materials. If you camp in the colder months, the floor will be cold. I put indoor/outdoor carpeting on top of my vinyl flooring. I can remove the entire piece for cleaning, including scrubbing and rinsing off with a hose if needed. I only did that once but have pulled it out for shaking/beating several times.
valhalla360
No paticular place.
Posted: 11/02/22 01:14am Link  |  Quote  |  Print  |  Notify Moderator
At one time, they were pushing carpet because the slide...slid across it and would tear up the vinyl over time. I think the newer ones no longer do that but might want to verify.
The trade off is you will see the dirt with vinyl but you can clean it. Reality is once the crud is down in carpet...it's there forever. I know lots of people with stains on the carpet that are never coming out.
Cold floors are easily addressed with some throw rugs.
Our preference is vinyl flooring (the planks would be fine so long as they don't interfere with the slide out).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
monkey44
Cape Cod, MA and Central Fla
Posted: 11/02/22 06:50am Link  |  Quote  |  Print  |  Notify Moderator
We have vinyl floor with throw rugs ... works great, easy to keep clean. We have no slides.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
way2roll
Wilmington NC
Posted: 11/02/22 07:01am Link  |  Quote  |  Print  |  Notify Moderator
The advantages to vinyl plank flooring is it's easy to put down, much easier to replace when damaged, lower profile, and it's cleaner than carpet.
2023 FR Sunseeker 2400B MBS
phillyg
SWFL
Posted: 11/02/22 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Have someone activate each slide while you observe/measure the carpet to bottom of the slide for adequate clearance. If any drag across the carpet close enough to the subfloor, you'll likely drag across any vinyl or plank flooring.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Cummins12V98
on the road
Posted: 11/02/22 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Glue down LVT/plank you do NOT want a floating floor. Damage a plank and simply pull it up re glue and replace.
35 years Commercial Construction experience. Saw a lot come and go but this is the best for your application.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
covered wagon
Posted: 11/03/22 09:03am Link  |  Quote  |  Print  |  Notify Moderator
The solution is to get the flooring farther under the slideout portion of the floor where the 2 floors overlap. I saw where an RV tech failed to do that properly and the slide would drag on the flooring and wrinkle it up for a distance while dragging it with the slide action.
The trick is to get it far enough underneath the slide floor so it has something to 'ride/ glide on and not create a pressure point of pushing the flooring. I always glue LVT/LVP in key areas and I have never had a problem. I have Laid a lot of it.
Be careful of what you buy as some if it does not lock together very well. I remember having to glue all the edge pieces because it came apart too easily. They got a good price but, paid more for the installation problems it caused.
To do a job correctly will often take extra effort. If your always looking for the easy way there may be some problems that arise as there is really no such thing as a free lunch but extra hard work always pays off where it counts.
