RV.Net Open Roads Forum: Roads and Routes: Route Planning Question
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Route Planning Question
valhalla360
No paticular place.
Posted: 11/03/22 12:27am Link  |  Quote  |  Print  |  Notify Moderator
ferndaleflyer wrote:
And for those that have never been where there is “no service” I suppose the answers above are fine. For me I’ll still use paper. I probably drive recreationally more than most and am also older than most. I am also technically challenged.
Google Maps allows you to download areas for offline use. I do it often when traveling internationally when I may not have cell coverage. If you check online, you can find coverage maps for your cell provider but it's usually pretty obvious when you get far from civilization and major roads, there's a good chance you won't have coverage.
I've actually had GM ask if I want to download the route for offline use. I haven't confirmed but I suspect if a substantial part of the route has minimal cell coverage, it tries to think ahead.
If you really are away from cell coverage a lot, there are full blown offline mapping apps where other than periodic updates, they are intended to operate away from the internet.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
austinjenna
Columbus, Ohio
Posted: 11/03/22 04:35am Link  |  Quote  |  Print  |  Notify Moderator
RV Trip wizard for me
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
Matt_Colie
Southeast Michigan
Posted: 11/03/22 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I am with both Gizmo's Mom and Valhalla here. What you also have to know is that at one time of my life my name tag had Navigator under the name.
Having paper maps (I still call charts) onboard is essential. When things stop working, all the paper needs to work as intended is that paper, a light source (so you can read it) and a Brain. I do realize that the last is asking a lot of some. If can't work one of those, stick to the blue roads where your cell phone has a good connection.
Like Gizmo's Mon, I am still using one of the old great planners. Mine is a 2015 copy of Street Atlas. It can also be a terrific enroute navigator with no requirement for outside support. All that takes is a GPS puck to make a laptop a tracking GPS with a big screen.
As to planning, I can complete the arrangement of a three week excursion before departure and as the navigator can modify the plan enroute, it is always correct even to the locations for breaks and fuel stops not to mention the location for your EOD - Whatever it is. That can be a Walmart, rest area or a Boondockers Welcome. The planning software is not preferential to anything except what you tell it.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Homeless by Choice
North America
Posted: 11/03/22 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
I use Street Atlas 13 and it works great. Mine is set up to avoid told roads.
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
mdcamping
CT
Posted: 11/04/22 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I use the Garmin for building out trips. I still use AAA maps with yellow highlighted routes as backups. google maps if I'm still not sure. And if I have to I'll post online for travel help.
Mike
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
ferndaleflyer
everywhere
Posted: 11/04/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Ok. Today I came to Baltimore. While still in NC I saw a friends son going up I 85 also I waved as I passed and he fell in behind, followed me onto I 495, then Rt 50 then MD Rt 3. His GPS had taken him this way but since he was going to upstate NJ he should have stayed on I 95. I got him pointed in the right direction but his travel time increased 2 + hours. A look at a map would have prevented this mistake.
valhalla360
No paticular place.
Posted: 11/05/22 04:33am Link  |  Quote  |  Print  |  Notify Moderator
I'm confused...he followed you but it's the GPS' fault?
I suspect, once he started following you, the GPS tried to update his route based on his new location.
