RV.Net Open Roads Forum: Class C Motorhomes: No LP to the stove top.
 > No LP to the stove top.
SCADAMAN29325
Clinton, SC
Posted: 11/04/22 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I'll be troubleshooting these items.
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19,
It may soon be home (in 4y).
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
SCADAMAN29325
Clinton, SC
Posted: 11/04/22 06:43am Link  |  Quote  |  Print  |  Notify Moderator
BTW, this is the first test of the LP. I figured the stove top is the simplest item. After this I will be testing the furnace, water heater and fridge.
Just having way too much fun!
enblethen
Moses Lake, WA
Posted: 11/04/22 07:34am Link  |  Quote  |  Print  |  Notify Moderator
There is a solenoid on the propane tank that is energized by the detector. The detector maybe bad. Most rigs do not have them.
You could remove the solenoid, get a stand-alone propane detector.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Dusty R
Charlotte Michigan 48813
Posted: 11/04/22 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Is the Manuel valve at the tank on?
Sandia Man
Rio Rancho, NM
Posted: 11/04/22 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Appliances that utilize propane are at times difficult to fire up, particularly when propane supply has been turned off for extended periods of time. Under this scenario in many cases air needs to be purged from LP supply lines before appliances will ignite. After turning on propane at tank, I turn burners on let air in lines purge lighting stove when I detect propane coming from burners, doesn't take long.
bob_nestor
murphy
Posted: 11/04/22 10:12am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar propane problem on my RV. In my case the first "appliance" to fail was my propane generator - it would start, run a few seconds and then die. The other appliances seemed to work fine. Isolated it to the propane regulator which I replaced and that fixed things.
While trying to figure out the problem I did quite a bit of research and discovered that there is some oil added to propane. Sometimes the propane supplier overdoes the oil addition. Over time the oil tends to collect in the regulator and gum it up reducing supply to appliances. The first ones to show problem are those which are higher users of the gas supply, such as my generator. But in time everything using propane can show signs of failure or cease to work all together.
SCADAMAN29325
Clinton, SC
Posted: 11/04/22 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, there is a manual valve on the tank.
After turning on the detector, I opened the manual valve and tried to light the pilot on the stove top. After a minute I turned the gas off.
I was hoping to hear the solenoid click when turning the power off/on on the detector but did not hear or feel anything.
I like the idea of removing the solenoid and getting a new sniffer.
Let's see how that goes.
bukhrn
Lanexa, Va
Posted: 11/04/22 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Those detectors have a life span, and should be replaced, I think its like 8 years mine has a "replace by" date on it.
2007 Forester 2941DS
2014 Ford Focus
SCADAMAN29325
Clinton, SC
Posted: 11/05/22 10:06am Link  |  Quote  |  Print  |  Notify Moderator
OMG, that is tight! Regulator and solenoid are too close to the tank to unscrew. Shot a little wd-40 on it and tapped it a little bit. I'll come back later I've got something else to work on.
enblethen
Moses Lake, WA
Posted: 11/05/22 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Remember it is left-handed thread going into valve!
By the looks of it, I would be looking for a new one.
