RV.Net Open Roads Forum: Class C Motorhomes: No LP to the stove top.
 > No LP to the stove top.
SCADAMAN29325
Clinton, SC
Posted: 11/05/22 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
What size flare nut wrench for this?
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19,
It may soon be home (in 4y).
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
enblethen
Moses Lake, WA
Posted: 11/06/22 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Checked mine, It is 7/8 inch. You shouldn't need flare wrench. Standard wrench or adjustable wrench. Your is damaged by looks in photo. May need small pipe wrench, then replace.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
San Diego Ca
Posted: 11/07/22 07:43am Link  |  Quote  |  Print  |  Notify Moderator
as stated above it's a left hand thread at the tank. In your picture you should be pulling up on the wrench to loosen.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
Posted: 11/07/22 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Definitely left-handed threads.
SCADAMAN29325
Clinton, SC
Posted: 11/07/22 09:04am Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Remember it is left-handed thread going into valve!
By the looks of it, I would be looking for a new one.
I skipped right over this!!! My SIL helped me out. GEEZ Phil!!!
SCADAMAN29325
Clinton, SC
Posted: 11/08/22 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Well, that was a little aggravating not having the right tools, but it's done.
Learned that the propane system uses lefthand threads on one end and right hand threads on the other.
The correct size wrench for LP connections is a good set of channel locks.
That no matter what you buy on Amazon, you'll still need to go to the hardware store at least twice, once to buy everything you think you need, and second, to take back what you really didn't need.
And usually I never throw away parts till way after the job is finished, but this time I did. I could have used a fitting, that I thought I already had.
Now on to testing the stove, fridge, water heater and furnace.
The water pump will be in a few days, that will be most of those parts.
TTYL
SCADAMAN29325
Clinton, SC
Posted: 11/13/22 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Thought I should post a pic of final install. The fitting between the regulator and 4-port could be a little shorter. And the fitting between the 4-port and valve needs to be a little longer (not enough room for a flare wrench, duh)
Now I need to start testing the appliances.
TTLY
enblethen
Moses Lake, WA
Posted: 11/13/22 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Looks close!
Regulator vent should be facing down. I cannot see it in photo. Regulators come in horizontal or vertical vent locations.
The Extends-a flow would have better access if rotated to make it easier to make connections.
I am being picky!
Was it easier to get off knowing it was left-handed thread?
SCADAMAN29325
Clinton, SC
Posted: 11/30/22 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
WE HAVE FIRE!
#enblethen
Thanks, I will take a look for that vent. And I did think about rotating the top port more toward the opening, but just wanted it done and over with. It still blows my mind that it had lefthand threads. I don't mind any of y'all being picky, I'm learning a lot about this thing
Thanks to all!
Phil
enblethen
Moses Lake, WA
Posted: 11/30/22 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to see you got it working!
Safe travels!
