SCADAMAN29325
Clinton, SC
This is where the TV antenna is. I would imagine that is either push, pull or twist.
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19.
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
Dusty R
Charlotte Michigan 48813
It's missing a crank & dial, that cranks up the antenna and turns it, it's directional, if I'm remembering right.
enblethen
Moses Lake, WA
This manual should help.
Winegard sensar
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
IAMICHABOD
Sunny So Cal
Dusty R wrote: It's missing a crank & dial, that cranks up the antenna and turns it, it's directional, if I'm remembering right.
It looks like it is missing These parts to move it around and the Handle to crank it up
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
CA Traveler
The Western States
With the missing parts, consider possible additional issues.
edited 11/04/22 10:28am by CA Traveler *
2014 Grand Cherokee Overland
Bob
enblethen
Moses Lake, WA
Missing spring!
IAMICHABOD
Sunny So Cal
enblethen wrote: Missing spring!
does it come with the spring?
Answer:
Yes, the spring is included in the RP-6200 kit.
By Winegard Company Manufacturer on September 27, 2017
Yes it should be included in the kit
By Tom Hackert on September 26, 2017
Hi yes it does. Thank you
By Carl's RV Parts & Service Seller on September 26, 2017
Yes it does.
By Amazon Customer on September 27, 2017
In kit referenced above.
edited 11/04/22 10:41am by IAMICHABOD *
SCADAMAN29325
Clinton, SC
Thank you again!!!
bukhrn
Lanexa, Va
Have you been on the roof? Is there even an antenna up there?
2007 Forester 2941DS
2014 Ford Focus
bobndot
Would replacing it using a new King antenna be a better antenna ? Anybody know ?
If deciding on going the solar route:
Replacing larger , weathered , old tech antenna with a smaller head new digital model which would leave more roof space for solar panels. The newer tech King might also draw less 12v power from ur coach battery bank. Something to consider , especially if boondocking is your plan.
There is a video of a direct swap , installing a new King.
Replacing old tv antenna with a King
