CA Traveler
The Western States
bukhrn wrote: Have you been on the roof? Is there even an antenna up there? Good one - LOL
2014 Grand Cherokee Overland
Bob
Tom_M
New Hope, MN
Since your antenna is almost 30 years old, I would suggest replacing the whole assembly. Your present antenna is probably a Winegard Sensar II. The latest is a Sensar IV. The Sensar IV has an added UHF element that sticks out the front. If you decide to upgrade, check your present antenna and make sure there is room for the new antenna when it is stowed. The Sensar IV is considered the best RV antenna. Also make sure that your coax cable and connectors are in good condition.
Here's a link to a Sensar IV assembly on Amazon:
Winegard Sensar IV on Amazon.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
IAMICHABOD
Sunny So Cal
When I bought my RV it had a Winegard Batwing that was not working, I cleaned up all connections and tested to see if it was broken, it was,so I replaced it with a new Batwing Head then ran a Channel Scan I was not impressed with the amount of channels that I got. This was done in my driveway here in the south bay of So Calif about 30 miles from the transmitters, using my SensarPro.
I then went out and got a Wingman add on, that put my channel scan up to 85,but I had a clearance problem with the Wingman,it hit my A/C.
So I opted to put a Jack Antenna and my channel scan went up to 174
![[image]](https://i.imgur.com/jo4c1hQl.jpg)
">]![[image]](http://i.imgur.com/7ZrhCTUl.jpgheight=220)
I always get beat up by the techies, The debate will go on and on, but I know what works best for me,in the real world.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
